Injen exhaust owner: How do you reduce drone inside the cabin?
Old Nov 23, 2007 | 07:50 PM
Riley07's Avatar
Riley07
An X pipe would be the way I would go...Dynamat is a great product, but you will get better results from the X pipe IMO...
Old Nov 24, 2007 | 09:47 PM
z-u-later's Avatar
z-u-later
Originally Posted by TAT_Z
Could you give the part no. of the magnaflow x pipe?
which injen u got? with ti tips?
There's a long thread here on this Magnaflow setup if you do a search. I think it's the 11385 but do a search to make sure. The dynamat recommendation ain't going to solve your problem. The x-pipe setup will not only solve your drone issue but your rasp issue as well. Added benefits are more torque and a bad azz exotic sounding exhaust.
Old Nov 25, 2007 | 10:12 AM
OCG35's Avatar
OCG35
Dynamat is good, but B-Quiet is lighter... I have a B-Quiet mat in my sedan trunk (HFC + Stillen Gen 1 is pretty loud and has drone)... You can install the adhesive material under the trunk mat, but I like to be able to remove it at the track for weight reduction, so the mat is my preference.
The sound-deadening product won't eliminate but definitely muffle the sound noticeably.
Old Nov 25, 2007 | 12:01 PM
jonnylaw's Avatar
jonnylaw
not to be an ***, but get a different exhaust. Everything else will just barely "deaden" the drone. But it will still be there. Try the dynamat/b-quiet. If that does not do it for you, look for swapping out some of your exhaust components to quieter setups. My .002.
Old Nov 25, 2007 | 01:10 PM
undrgnd's Avatar
undrgnd
Does anyone here have experience with dampers? Are they all the same, or is one better than another? Any unique designs out there that actually make a big difference? If someone could not use an X-pipe, what kind of damper would you get?
Old Nov 28, 2007 | 11:01 AM
EricChan's Avatar
EricChan
Banned for NON PAYMENT
If i remember, I saw that Apexi made an exhaust Valve controler. Anybody have experience with these? it allows you to control the exhaust output volume from inside the cabin manually or electronically.
Old Nov 28, 2007 | 05:11 PM
JonsilvZ's Avatar
JonsilvZ
Be a man and use your *****. My gf doesnt complain about the Injen drone. She knows better
Old Feb 16, 2015 | 04:50 AM
marcoferrario's Avatar
marcoferrario
Hello guys.
I have the same problem with the Injen exhaust.
Too much drone in the cabin, especially towards 2000 rmp
Someone has replaced the two Injen resonators with a X-muffler? I would like, if possible, a photo: i read that should solve the problem.
This may be fine?
http://www.ebay.it/itm/251810368293?...84.m1438.l2649
Thanks and greetings from Italy !!!
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Justin100
Nov 29, 2015 03:58 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
