Non fouler question
Since non foulers pull the O2 sensor away and out of the direct exhaust stream, wouldn't that cause the car to run somewhat poorly b/c it's not reading accurately?
No. The heated oxygen sensor 1 signal is sent to the ECM. The ECM adjusts injection pulse duration to achieve the proper air-fuel ratio.
Heated oxygen sensor 2 monitors the oxygen level. Under normal conditions sensor 2 is not used for engine control operation.
EDIT: You cannot remove and discard the oxygen sensors. The ECM monitors the switching frequency of sensors 1 and 2 to detect a catalytic converter malfunction.
