Got a MREV2
Old Jan 5, 2008 | 01:28 PM
  #221
undrgnd's Avatar
undrgnd
Originally Posted by Money0veru
That looks like its right to 7000rpms to me.
No, that's almost 6900 though. Interpolation 101: 6680+2((6680-6160)/5)=6888. Close enough.
Old Jan 5, 2008 | 01:29 PM
  #222
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Try posting the vids on YouTube.
I contacted Julian this morning and found it may not be possible to export the dyno data to Excel for additional analysis. The dyno software doesn't normally export the data in text format. I will contact Dyno Dynamics to see if it can be done.
But even without the additional analysis in Excel, with just a visual inspection, the dyno plots make it clear... there is no other NA REVUP bolton more effective than this.
Old Jan 5, 2008 | 01:51 PM
  #223
Hydrazine's Avatar
Hydrazine
Default 5/16" Vs 1/2"
RBlover,
I remember you were asking about the differences between the 5/16" and 1/2" spacer on the MREV2.
Although there has not been a direct comparison of the two spacers on a MREV2, these plots here can give you a good idea of what is happening between the dynamics of spacer size, internal volume and their relation to HP and area under the curve.
There is not much difference between the 1/2" and 5/16" but there is some difference that can be consistantly measured.
Compared to the 5/16" spacer, the 1/2" makes a little more HP above 6K and a little less area under the curve below 6K.
If you look closely at the midrange of these newly generated MREV2 curves, you will see a slight loss of midrange when the 5/16" spacer was added.
I've seen this same trend on every REVUP test I've ever done.
When you put on a 1/2" spacer, the midrange loss is even greater but there isn't quite enough increase in the top end to compensate for the loss everywhere else.
Basically, a minimized plenum internal volume is good for TQ and area under the curve. A maximized plenum internal volume is good for very high end HP.
I did all this same extensive testing, with every configuration, on the MREV and MREV+.
Overall, the 5/16" spacer is slightly better optimized.
Just a FYI.
Old Jan 5, 2008 | 04:20 PM
  #224
RBlover69's Avatar
RBlover69
Originally Posted by Hydrazine
RBlover,
Just a FYI.
thanks hydra always a pleasure reading some of the tests clearly you have a great product that shows what testing was done because the results are obviously great. I guess the reason my doubting the 5/16 over the 1/2 was peak hp. Of course since i traded the 287 for the higher peak in the revup and since it was really designed to be more of a peak motor then have the tq of the previous DE i wanted to increase the peak while gaining the tq, but your expaination if the nature of the beast is def sound and i finally understand why the 5/16 overall would be better. Now i need a GB on the 5/16 and the mrev2 or a after new years special lmao jk.. Im gonna def get this setup now gotta pick up my exhaust thurs and now i gotta get this in 2 weeks you will be hearing from me and the dyno of course .
Old Jan 5, 2008 | 07:38 PM
  #225
BakaN20's Avatar
BakaN20
Stock with nismo exhaust
http://www.youtube.com/watch?v=_UZyD54mvFY
Nismo with mrev2
http://www.youtube.com/watch?v=9stj6mIbrxI
Nismo with mrev2 and 5/16 spacer
http://www.youtube.com/watch?v=8t92o48iR8E
Old Jan 7, 2008 | 07:51 PM
  #226
WyattH's Avatar
WyattH
I know on REVUPs, the COMBO is recommended... But would a REVUP with ONLY the spacer (not Mrev2) dyno something similar to the green? How would JUST spacer compare to JUST MREV2?
Old Jan 7, 2008 | 11:15 PM
  #227
Mazinger Z's Avatar
Mazinger Z
Congrats on the MODIFIED MAG article!
Old Jan 8, 2008 | 02:08 AM
  #228
Heatt's Avatar
Heatt
Hi Tony,
Was reading up on the previous posts and about authentic MREV2 and what not. I got my MREV2 and spacer end of 2006... received them early Jan 07. Just want to make sure i got the genuine parts. I only managed to take some pic of the MREV2 then and might not be clear. Wondering if you can tell if mine's genuine. Thanks heaps...!!
Old Jan 8, 2008 | 05:32 AM
  #229
Hydrazine's Avatar
Hydrazine
Heatt,
Yes, what you have is real.
Jason (Bugsbunny),
I havn't seen the article yet. Is it on the stands now?
Old Jan 8, 2008 | 07:05 AM
  #230
Heatt's Avatar
Heatt
Awesome... thx for clearing that out... i can sleep properly tonight! <3
Old Jan 8, 2008 | 09:18 AM
  #231
jonnylaw's Avatar
jonnylaw
Heatt,
Jason (Bugsbunny),
Just picked up the latest modified at the local newstand. Indeed the G35 project car has installed a MD MREV2 and 5/16 spacer and good gains were had and the staff's opinion of them are great. Congrads Tony!
The mag also picked a stillen exhaust and stillen intake for the g35 project car
Old Jan 9, 2008 | 11:44 AM
  #232
WyattH's Avatar
WyattH
Old Jan 9, 2008 | 12:41 PM
  #233
Hydrazine's Avatar
Hydrazine
The spacer by itself doesn't do much on a REVUP lower plenum. The MREV2 works all by itself on a REVUP but it works even better with a spacer.
If you can only do one or the other, start with the MREV2. You can always add the spacer later for more top end.
Old Jan 9, 2008 | 09:36 PM
  #234
phat04350z's Avatar
phat04350z
So is it to say on the non revup motor ie a 2004 350z when you add the MREV2 and spacer the gains will be around 30-40hp correct? If so what spacer I am confused on that when reading all this...
Old Jan 9, 2008 | 09:56 PM
  #235
Hydrazine's Avatar
Hydrazine
No. They don't add up like that.
For your application, I recommend just the 5/16" spacer. It has the best bang for the buck.
Its fairly easy to install too.
Old Jan 10, 2008 | 03:54 AM
  #236
phat04350z's Avatar
phat04350z
I thought with a non revup motor we have a limited air flow and the MREV2 allows for more airflow? I believe on there website it said the MREV2 will work in a non revup motor and will allow for more HP. Correct me if I am wrong.
Old Jan 10, 2008 | 06:34 AM
  #237
Hydrazine's Avatar
Hydrazine
Yes, it does. Performance is very much like a spacer on the non-revup engine but with a little more TQ.
Wired24/7 (Mike the moderator) did a series of dyno tests on it and posted the results a while back.
Note: The average gains with the MREV2 is very slightly higher than that of the spacer. But because it costs more, this is the reason why I generally recommend the spacer for "Bang for the buck".
Old Jan 10, 2008 | 06:35 AM
  #238
Reality350's Avatar
Reality350
You mean on Hydrazine's website?
Well you pretty much heard from the man himself. Go with the 5/16th spacer.
Cheers,
Old Jan 10, 2008 | 06:56 AM
  #239
Hydrazine's Avatar
Hydrazine
Mikes test results of MREV2 on a non-REVUP engine:
https://my350z.com/forum/showthread....ighlight=mrev2
Old Jan 10, 2008 | 12:34 PM
  #240
ke0ki2k's Avatar
ke0ki2k
why doesnt everybody just order their **** directly from Motordyne? thats what im gonna do...
