how to fix a stripped plenum bolt?
Old Dec 20, 2007 | 05:41 PM
SuperBlack350z's Avatar
SuperBlack350z
Default how to fix a stripped plenum bolt?
i did a check on my plenum bolts today, making sure they havne't loosened over time. There was this one bolt in the top left corner. It seems that it's stripped. This sucks. Before i try to mess with it (so fragile), anyone know how to fix the problem properly? Not sure where to find these bolts as well. I guess the only way is getting a thicker bolt? i just dont' want to crack anything.
Old Dec 20, 2007 | 05:53 PM
SuperBlack350z
bump
Old Dec 20, 2007 | 06:04 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Remove the bolt. Try to retap the hole if you can. This works sometimes.
If the threads are gone, drill out the threads and re-tap the hole. You will need the right sized drill and tap.
Old Dec 20, 2007 | 06:07 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
get a heli coil kit just drill it out straight very important that its straight all it doesnt come with is the drill bit it will be easy on a plenum. just go slow and careful.
Old Dec 20, 2007 | 06:09 PM
SuperBlack350z
ok, cool, thanks guys. I'll get a heli coil kit tomorrow. I was going ot pick one up from the snap on guy last month but thought i would never use it.
Old Dec 20, 2007 | 06:10 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
is that a tap kit? or is it a heli coil kit you usually have to get those from napa or auto zone. The heli coil kit you need is 6x1.00.
Old Dec 20, 2007 | 06:12 PM
SuperBlack350z
It's a heli coil kit. A tap kit is different. Thanks for being precise for what i need. Big help.
Uriyo_
Sep 8, 2021 08:46 AM
