Will Evo TT clear Eibach sways?
Old Dec 21, 2007 | 07:43 AM
Changvi's Avatar
Changvi
Default Will Evo TT clear Eibach sways?
I currently have a set of eibach sways on my car. Front is set to full stiff, and the rear is set at the middle slot out of the three. As i was looking at the clearance in the rear, i sort of having second thoughts about whether EVO TT will clear through the sway bar. Does anyone have Eibach sways with EVO TT? I need feed backs asap, since this is keeping me from pulling the trigger on an EVO TT. Thanks guys
Old Mar 6, 2009 | 03:19 PM
G35cTT's Avatar
G35cTT
Would like to know as well thinking of gettin some Eibachs or Hotchkis, I have the Ti C TT that's sort of similar.
Old Mar 6, 2009 | 07:18 PM
BaZooKa's Avatar
BaZooKa
i dont have a sure answer ,, but after installing the evo TT the oem rear sway bar was so close from the exhaust as if they are touching ..
Old Sep 5, 2009 | 01:12 AM
G35cTT's Avatar
G35cTT
I've just installed the Hotchkis and it clears no problem and they work great. If the Eibachs are the same shape bar in the rear then you should have no problem clearing the exhaust.
Old Sep 13, 2009 | 01:31 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
that should not be the case I had hotchkis sways and an EvoTT on my old Z and even that didn't have any problem.
