o2 eliminator
Old Jan 10, 2008 | 09:01 AM
2boosted4u's Avatar
2boosted4u
Default o2 eliminator
where would i find some o2 eliminators for my 03 track cause i just ordered some test pipes and i wanted to get them before i get the CEL
Old Jan 10, 2008 | 09:02 AM
iStan's Avatar
iStan
ZR
Eliminator or non fouler?
If later, just search and you'll find a DIY to make it.
Old Jan 10, 2008 | 09:43 AM
2boosted4u's Avatar
2boosted4u
^ which ever i need so i dont get a CEL (on my lightning they were called o2 eliminator)
Old Jan 10, 2008 | 12:24 PM
UY350Z's Avatar
UY350Z
kragen
Old Jan 10, 2008 | 12:56 PM
theking's Avatar
theking
03's don't usually get O2 codes because of test pipes. I wouldn't worry about it. My O3 G35 with built motor and TT never got them. I never got them when I was NA with test pipes either. Search and you can probably find that out.
Old Jan 10, 2008 | 01:34 PM
superchargedg's Avatar
superchargedg
Damn Noobs
+1
Old Jan 10, 2008 | 03:22 PM
undrgnd's Avatar
undrgnd
Same place you got them for your Lightning?
Old Jan 10, 2008 | 03:52 PM
2boosted4u's Avatar
2boosted4u
i had a hand held tuner to clear the codes so i never bought them lol and i was goin to get em use from my old forum svtperformance
Old Jan 10, 2008 | 04:39 PM
gothchick's Avatar
gothchick
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/194001-test-pipe-ses-non-fouler-fix-pics.html
Old Jan 10, 2008 | 05:19 PM
Ztalker's Avatar
Ztalker
Old Jan 10, 2008 | 08:51 PM
2boosted4u's Avatar
2boosted4u
come on man that would just be WAY too easy ^
Old Jan 11, 2008 | 11:21 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
I've got an 03 w/ test pipes and I never got a CEL from not using eliminators. I'd install the test pipes, reset your ECU, and drive around a bit to see if you throw a light. I'm pretty sure you won't.
Old Jan 11, 2008 | 11:35 AM
malized's Avatar
malized
guys, tomorow i'll install my APS test pipes, today i was checking the OEM cat's, and its really difficult to replace them ... what do u think ? did some one have a link to install them easily ???
''Sorry to be offtopic''
Old Jan 11, 2008 | 11:47 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
I won't lie, it's pretty damn annoying. The worst part for me was getting to the nuts that hold the cats to the headers. I had to use a 4 foot extender connected to two universal joints to get to it. It's 10 times easier with pneumatic tools, which I used. Another annoying part was my y-pipe seemed to be wider than the test pipes. I had to man handle the y-pipe to align with the bolt holes in the new pipes. Try to get someone to help you with this project as I cannot imagine doing it myself. I'm sure we've got a DIY on the forums somewhere. Check https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/300513-diy-header-hi-flow-cat-installation.html for a header/test pipe install. You could just use that and just bypass the header part.
Oh, one other tool you'll need is an 02 sensor wrench. You can get this from any auto parts store.
Old Jan 11, 2008 | 12:05 PM
malized's Avatar
malized
Originally Posted by USMC-Z
I won't lie, it's pretty damn annoying. The worst part for me was getting to the nuts that hold the cats to the headers. I had to use a 4 foot extender connected to two universal joints to get to it. It's 10 times easier with pneumatic tools, which I used. Another annoying part was my y-pipe seemed to be wider than the test pipes. I had to man handle the y-pipe to align with the bolt holes in the new pipes. Try to get someone to help you with this project as I cannot imagine doing it myself. I'm sure we've got a DIY on the forums somewhere. Check https://my350z.com/forum/showthread.php?t=300513 for a header/test pipe install. You could just use that and just bypass the header part.
man i have an amzing oportunity that im changing the ''Syncro'' so my gears box is out the car so i can work easily... but how if my gear box is on the car ??
Old Jan 11, 2008 | 12:23 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
You don't have to take the gearbox out to get to the pipes. It's very easy to get to from the bottom, but the top bolts are the problem. Make sure you have the car up on jack stands so you have enough room to get under the car. I'd put auxiliary jack stands as a fail-safe.
z33z_nutz
Sep 23, 2015 07:22 PM
