G35 plenum spacer on a Z
Old Feb 1, 2008 | 01:14 PM
s3fddiZ's Avatar
s3fddiZ
Default G35 plenum spacer on a Z
Will it fit? The guys from Motordyne aren't responding to me and I can't seem to find much searching.
Old Feb 1, 2008 | 01:17 PM
ahero4eternity's Avatar
ahero4eternity
Vendor - Former Vendor
it'll work....
Old Feb 1, 2008 | 01:18 PM
s3fddiZ's Avatar
s3fddiZ
Awesome, thanks for the quick response!
Old Feb 1, 2008 | 01:24 PM
HondaKiller's Avatar
HondaKiller
i'm sure the spacer will fit, but the bolt kit might be slightly different? Might want to check with tony.
Old Feb 1, 2008 | 01:26 PM
davidc81's Avatar
davidc81
will work all the same!
Old Feb 1, 2008 | 01:27 PM
ahero4eternity
nope...it'll work.
Old Feb 1, 2008 | 01:29 PM
drsifu's Avatar
drsifu
1 vq35de engine = 1 vq35de engine
Old Feb 1, 2008 | 01:30 PM
ahero4eternity
my vq35de engine > everyone elses!
Old Feb 4, 2008 | 01:46 PM
bryan@Z1's Avatar
bryan@Z1
It should fit without any problems. We have the Z1 Plenum spacer on our G35.
Old Feb 4, 2008 | 06:44 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes, it will fit if its a 1/2" spacer.
If its a 5/16" spacer, you will need the strut bar spacer.
When did you try to contact us? I'm, almost, always available.
(661) 993-5111
Tony
PS - If you were the one asking the question about M10 bolts with the 1.25 thread pitch, I just came across your email today. My direct email is info@motordyneengineering.com
Otherwise, yes, M10@1.25 thread pitch should fit. If it didn't, check to make sure you have the same thread pitch as the stock bolts.
Bring a stock bolt with you to the hardware store and simply get the exact same size bolt 30mm long. You can put the stock bolt threads up against the new bolt and they should fit together perfectly (assuming they are the same pitch).
Call me if you have any questions.
Old Feb 4, 2008 | 09:01 PM
s3fddiZ's Avatar
s3fddiZ
you responded to my email about 15 minutes after I posted the thread. Thanks for the info man. The spacer should be getting in on the 11th, so probably the next weekend I will try to install it.
pdexta
Sep 14, 2015 11:27 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
