High flow cats questions
Old Feb 9, 2008 | 12:56 PM
Berk_Technology's Avatar
Berk_Technology
Originally Posted by 03aeroZ
so since most cats have the same cell count, are the same design (in general), and made of roughly the same material, can they really sound that different?
They will all sound roughly the same. The exhaust will have a greater impact on the resonance of the exhaust system as a whole than just the cats.
But it is a big misconception about the HFC's all being roughly the same. There are a lot of manufacturers that are taking your run of the mill replacement catalytic converter and calling it a "high flow cat". Chestobo just published some results from one of these other so called 07 350Z "high flow" cats. They performed just barely above the factory 2007 units.
The results were skewed in favor of the Technosquare HFC's that he was testing against, but the data itself was very useful and much appreciated.
FastIntentions metallic HFC are very high quality. You do not need or want to brace them as they are light compared to the stock parts and most aftermarket cats and test pipes are more prone to crack IF you try to brace them. Don't!
If you want max performance, get the 300 cell metallic. Otherwise get the 400 cell ceramic (cheaper and just fine for NA). You can get an extra bung for an aftermarket wideband installed pre-cat for $20 (they ship with a plug so if you don't have a wideband right now, it'll work fine).
The Berk units place the extra bung for an aftermarket wideband after the cat when it should be before - I would double check on this before ordering from them (the stock widebands are supposed to be after the cat, but not aftermarket) .
After studying the factory cats and how Nissan braced them we've decided that they do need the same support tabs that the stock cats have. That support tab just needs to be properly gusseted. Lighter or not, the cats need a support tab. That's why you now see the majority of test pipes with support tabs as well. Test pipes are a hell of a lot lighter than any HFC, yet they still need support tabs.
Fast Intentions is able to get away with not using support tabs on their HFC's because they are using an angled outlet cat. The stresses of the engine twist are placed on the top side of the cat vs. the inside radius of the bend on the pipe. That radius is taken up by the top of the angled cat. (Edit: But, you can still crack through the cat itself, despite the weld holding up. Just saw a set of FI HFC's today that were cracked through).
If anyone who orders our product and you want another pre-cat wideband bung & plug then send me an extra $20 and I'd be happy to weld another one in there.
Berks do have a brace.
You are correct as of last Wed. All HFC's (03-06 & 07-up) will have our fully gusseted support tabs. During the 1st part of 2008 only the 2007's had our support tabs.
The engine is trying to push the cat down, while the exhaust is trying to hold it up. The cat will try to bow downwards. The support brace holds the cat up and transfers those stresses to the tranny instead of the exhaust & cat.
Hope that helps!
Cheers,
Bryan
Old Feb 9, 2008 | 07:28 PM
singh's Avatar
singh
_______________
Interesting.
I'm looking to buy your HFC for my 07. Still on the fence about it though.
Old Feb 10, 2008 | 11:52 AM
03aeroZ's Avatar
03aeroZ
great info...thanks
Old Feb 10, 2008 | 12:19 PM
toyn2time's Avatar
toyn2time
I have Crawford cats right now and have had them on the car for a little over a year. From what I understand, they are just "gutted" stock cats. Not really sure what that means entirely. Needless to say, I should've done more research as I not that thrilled with them. I will be buying Berks shortly.
Old Feb 10, 2008 | 06:07 PM
BakaN20's Avatar
BakaN20
So the Berks just makes the nismo exhaust sound louder and does not change or take away from the nismo? i love the sound of the nismo. Also, how will the hfc be on emissions testing, will there be a problem passing? It seems like an hfc/test pipe is the next best n/a mod on a revup after a spacer/mrev2, just making sure that is true.
Old Feb 11, 2008 | 09:32 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
^^ +1
Also, can berk clarify about the positioning of the second bung for the aftermarket wideband O2 sensor.
Old Feb 11, 2008 | 10:22 AM
gothchick's Avatar
gothchick
Originally Posted by Sick Z
I have ran both FI and Berk. And I know some friends that run Crawfords. They would have to agree though, after we installed my Berk HFCs, that they are really great quality, come with an extra bung for a wideband, and great price! Definitely cheaper than FI and Crawford.
EDIT: Berks also have a built in CEL fix just in case you still throw a code with HFCs.
Just make sure the WB O2 bung is upsteam of the cat or the AFRs will be inaccurate. Ie. Too lean.
Old Feb 11, 2008 | 11:33 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
That seem's like a bit of a doodoo if berk put the WB O2 bung after the cat then.
Old Feb 12, 2008 | 11:45 AM
Berk_Technology
If you want a pre-cat bung on there then just send me an extra $20 and we'll TIG one in there for you.
Old Feb 12, 2008 | 01:10 PM
stylett9's Avatar
stylett9
I had Berk HFC's with my Nismo and let me put it this way. Before the HFC's, i thought the nismo sounded perfect and was weary of installing HFC's to change the sound. Afterwards, i didn't regret it one bit. Do you love the sound if your nismo but wish sometimes it was a bit louder? That's exactly what the berk HFC's will do for you. Louder, but not too loud. You should still pass emissions with Berk HFC's.
Old Feb 12, 2008 | 02:50 PM
usmanasif's Avatar
usmanasif
Bryan, I am interested in getting your HFCs for my '06 to mate them to my Nismo C/B. Would you please PM me your shipped price to 80108?
Old Feb 12, 2008 | 03:40 PM
SniperHunter's Avatar
SniperHunter
If I got HFCs (Berks are the top of my list), how much would sound increase when at cruising speeds (30 & 60-70MPH)? My Borla TD is flawless in this regard, and I want to retain that quietness in the lower RPMs as much as I can if I get HFCs - which is why test pipes are totally out of the question for me.
So, how drastic will the sound increase be?
Old Feb 12, 2008 | 04:11 PM
BakaN20's Avatar
BakaN20
same to 18324, got any military discounts? Lol, doesn't hurt to ask
Old Feb 12, 2008 | 04:24 PM
stylett9's Avatar
stylett9
I dont' know about with a Borla, however, with my Nismo after the car has warmed up, you could barely notice it durring idle and cruising. Durring acceleration the sound is definately present, but not obnoxious.
Old Feb 12, 2008 | 08:58 PM
itsjiggajames's Avatar
itsjiggajames
I agree. Although the nismo is a lot louder after getting HFCs.. it's not annoying farting loud like i've seen with MANY setups with either Test pipes or HFCs. I just dislike my slight rasp at 2800-3000rpms under warmup.. (first 5-10mins) after, i can run it as hard as I want and not a hint of rasp. Warm-up is louder too, but all Z people know that the car runs very rich and at higher rpms to cause those sounds. BTW i have some soundclips of NISMO and HFC posted already under the HR forum.. just not that great of a vid. Will make another one soon..
Old Feb 12, 2008 | 09:26 PM
03aeroZ's Avatar
03aeroZ
so if the o2 bung is needed anyways...why make it an extra charge? i don't get why it isn't just an automatic thing? to be more specific...the placement of the bung....if it is to be pre cat or not...why not have it like the stock set up?
Old Feb 12, 2008 | 09:59 PM
solidsnake's Avatar
solidsnake
Has anyone seen the JVT racing cats? The price seems right but nobody has installed them so Im a little reluctant to get them just yet.
Old Feb 13, 2008 | 05:58 AM
  #38
gothchick's Avatar
gothchick
They're talking about the WB o2 (for tuning purposes).
Old Feb 13, 2008 | 07:50 AM
  #39
scmtkings4's Avatar
scmtkings4
any of you guys know why Berk decided to add a brace to their HFC? Is it because they found problems with their original HFC? Im one of many of the members here who have bought the HFC before the brace was put on
Old Feb 13, 2008 | 09:52 AM
  #40
Berk_Technology
are your HFC's still holding up fine after all these months? yes. so NPF (no problem found).
It's all about making your products better, constant improvement over here. Any product in the world can be made better, weather it be car parts, TV's, or laundry soap. Once you stop improving, that's when you start to fall behind. Take a look at what's happened to Ford & GM over the years. And now take a look at Toyota, Nissan, & Honda. You never want to be that guy....
Hope that helps...
