best plenum spacer for 350z??
Old Feb 6, 2008 | 08:40 AM
novaturnedz77's Avatar
novaturnedz77
Default best plenum spacer for 350z??
Looking for a good
no make that great plenum spacer any suggestions?
Old Feb 6, 2008 | 08:46 AM
phreaktor's Avatar
phreaktor
Design Engineer
Search the site, read what you find, and then ask more specific questions. Otherwise you will be flamed to death.
You have Skunk2 (which I have)
Motordyne
AAM
OBX
Most people here will tell you to get eh Motordyne because you won't have to replace your strutbar. They're all basically just a piece of material that adds hieght to the plenum. As long as it's sealed, does it really matter how much money you spend?
blasian's Avatar
blasian
+1 to what he said.
Old Feb 6, 2008 | 08:50 AM
cdoxp800's Avatar
cdoxp800
there all about the same. Most people run the 5/16 on the REV up's. This way you retain the factory brace.
Cm
Old Feb 6, 2008 | 09:39 AM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
MOTORDYNE, besides making the best power and retaining your factory strut bar Tony has top notch customer service and A+ products. Also active member on this forum.
Old Feb 6, 2008 | 09:53 AM
HondaKiller's Avatar
HondaKiller
not to mention MD spacers are coming down in price to be more competitive with the less popular brands. I just like the fact that you can call the engineer on the phone with any questions about the spacer or install. Now lets see you do that with Skunk, or OBX. Case closed. MD FTW
Old Feb 6, 2008 | 09:56 AM
Old Feb 6, 2008 | 10:00 AM
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
Motordyne 5/16 spacer hands down is the best, easy install and keep your stock strut bar.
Old Feb 6, 2008 | 01:19 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Motordyne by far. I have installed other brands for others in our club, and the quality is much better. They at least give you the stops to put inside your plenum to keep it from flexing when you tighten it down to the in. lb torque spec, and some have broken their manifolds (cracked them) due to flex.
Old Feb 6, 2008 | 01:22 PM
Nexx's Avatar
Nexx
the new intense power spacer looks to be a winner and you really want go wrong with MD.
Old Feb 7, 2008 | 03:23 AM
zyou8er's Avatar
zyou8er
Sorry to ask, but does a plenum spacer voide your warranty? Tnx
Old Feb 7, 2008 | 03:33 AM
badkarma85's Avatar
badkarma85
An alternative to the MD spacer is the Pure Innovations spacer.. Brainchild of one of the admins on the other site
Old Feb 7, 2008 | 04:41 AM
phreaktor's Avatar
phreaktor
Design Engineer
Why would you need to talk to an engineer about a plenum spacer install?
Also, it's just a piece of metal that adds space, not some sort of active temperature control unit. They all function the same as long as the seal is tight. Thickness, however, does make a difference.
Old Feb 7, 2008 | 04:57 AM
Rowlett's Avatar
Rowlett
Easy Install! I went with a Pure Inovations Space.... Nice gains low cost but they all run about the same...5/16 spacer is Mid range power...the bigger ones give you Top end...
Old Feb 7, 2008 | 05:02 AM
SlideFox's Avatar
SlideFox
Powerlab has been selling TONS of there 3/8" plenum spacers.
Old Feb 7, 2008 | 05:20 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Yes Fast Shipping, Great Service and Unbeatable quality from PowerLab & us
Old Feb 9, 2008 | 05:40 AM
Justinw1313's Avatar
Justinw1313
Idwin- is that a gold desert eagle?
Old Feb 9, 2008 | 07:59 AM
citymunky's Avatar
citymunky
NO
Old Feb 10, 2008 | 02:20 PM
NA350zJimmy's Avatar
NA350zJimmy
Old Feb 10, 2008 | 02:57 PM
ladyzed's Avatar
ladyzed
Can you use an aftermarket upper plenum in conjuction with this spacer too ?
