Powerlab 3/8 plenum spacer
Old Feb 12, 2008 | 08:39 AM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
The reason why the spacer appears to "hang out" is because it was modeled (Drawn) after the lower intake manifold, not the top portion. The section where it sticks out, the upper plenum has a very narrow sealing surface compared to the lower plenum.
If you look at the pictures you can see it sits flush with the lower section There's nothing wrong with it, it's better actually since it creates a larger sealing surface.
Old Feb 14, 2008 | 01:09 PM
BeejZ's Avatar
BeejZ
Originally Posted by chromesilver6
I had no issues installing my spacer except fot the fact that i only got 4 of the little black plastic spacers for the mid plenum bolts instead of 6. weird.
My kit was also missing 2 of the black spacers. Other then that I have no complaints.
I am curious to see what it dyno's. SOP feels good but it feels to have lost some low end torque. We will see though. The power band is definatly different, but it does feel like a totally different car at WOT.
Old Feb 14, 2008 | 05:21 PM
texasZ350's Avatar
texasZ350
seems like some of these kits are missing 2 of the black spacers? i can only guess that that is necessary for install....what have you guys been doing? thanks
Old Feb 14, 2008 | 06:01 PM
Carter86's Avatar
Carter86
i have the same problem. The strut bar is hitting the plenum cover when im giving full throttle. Not a big deal and i can feel the power difference
Old Feb 14, 2008 | 06:09 PM
BeejZ's Avatar
BeejZ
I have it all together with out it, just don't over tighten those bolts. I contacted the vendor and they are sending me the two pieces. Not a big deal.
Old Feb 16, 2008 | 05:13 PM
paulbk's Avatar
paulbk
Unhappy
Old Feb 16, 2008 | 10:57 PM
DRELOC's Avatar
DRELOC
Wow powelab 3/8 spacer look almost as thick as the 1/2in motordyne and still retain stock tower bar....decisions decisions lol
Old Feb 17, 2008 | 08:10 AM
IIQuickSilverII's Avatar
IIQuickSilverII
humm..well you've seen the looks, you know the quality of the material...u've seen it performs... now also ask your wallet...hehe overall the choice is easy IMO
Old Feb 21, 2008 | 11:33 AM
ladyzed's Avatar
ladyzed
^ Good call.
I will choose powerlabs spacer for sure.
Old Feb 21, 2008 | 11:37 AM
INTENSEPOWER's Avatar
INTENSEPOWER
Vendor - Former Vendor
Greetings and salutations,
All: thanks for your positive posts.
Thanks again.
D
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
