How Hot Do Exhaust Tips Get?
Old Feb 26, 2008 | 03:05 PM
whitecel's Avatar
whitecel
Default How Hot Do Exhaust Tips Get?
Basically, I bought an x02 exhaust today thinking that tip just had dirt on it. Come to think, it was rust on the tips. When I tried wet sanding with 2000 grit, it took the whole blue coating off. So I'm just going to paint the tips and was wondering how hot it gets. High temp paint has limited color so was wondering if regular paint will hold up to the heat.
Old Feb 26, 2008 | 03:11 PM
SuperBlack350z's Avatar
SuperBlack350z
You should drive your car how you would normally do and after you stop and turn the car off, touch your exhaust tips to see how hot they get. It's easy to determine if it's low heat or high heat.
Old Feb 26, 2008 | 03:15 PM
r_seng's Avatar
r_seng
the only why you'll find out is if you lick it.
Get_Zwole's Avatar
Get_Zwole
xo2 is prone to rust shouldnt have bought a knockoff and been cheap
Old Feb 26, 2008 | 03:30 PM
whitecel's Avatar
whitecel
Are you being serious about that?
And to the rest, thank you for the entertaining comments. What is done is done. Be glad it isn't you who was retarded enough to buy it
Old Feb 26, 2008 | 03:32 PM
SuperBlack350z
Yes i'm serious. There is no better way of seeing if your exhaust tips get hot or not.
Concave's Avatar
Concave
if i bought the x02, personally i probably would have painted the entire exhaust in high heat paint that stops rust. (most likely flat black)
then i would hope that it works :P
Old Feb 26, 2008 | 03:37 PM
dieselmcore's Avatar
dieselmcore
ok, heres a quick and handy way
high temp. paint comes in either +120 deg. cel. or -120 deg. cel.
After u drive around, step out, get a small bottle of water, and pour some on the tips, if the water evaporates instantly, u need the +120 deg. cel. paint...
If it sort of just simmers a bit, or does nothing significant, get the -120 Deg. cel.
I am a noob, but hope this help...
Old Feb 26, 2008 | 03:46 PM
whitecel's Avatar
whitecel
thanks i'll try that. The crap part is...i won't be installing for a while so i wanted to do this before hand. But then again, they are so easy to take off.
thanks all!
Old Feb 26, 2008 | 05:46 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The exhaust gas at the end of the exhaust system can easily reach 800'F.
I wouldn't paint it because your only options are silver exhaust system paint or colored BBQ paint... and none of them would look good on your exhaust tips.
The best thing you can do at this point is simply polish the rest of the tips to a good clean shine.
There isn't much else you can do.
Old Feb 26, 2008 | 06:31 PM
Ruthless18x's Avatar
Ruthless18x
hahahahaha thats messed up he's prolly dumb enough to try that.
Old Feb 26, 2008 | 11:03 PM
whitecel's Avatar
whitecel
Lol sorry. You must be dumb enough not read my reply to him.
Back on topic. I didn't know it reached up to 800 at the tips. Thought it would be a little less. Anyway, I'm thinking of just wet sanding the rust off and then polishing the best I can.
When they totally crap out, I can just buy tips with the same diameter and drill holes. O well, it's a problem, but at least there is a solution.
Thanks all for the help
Old Feb 26, 2008 | 11:20 PM
SuperBlack350z
My tips on my nismo exhaust doesn't get hot at all. I can touch mine right after driving for half an hour.
Old Feb 26, 2008 | 11:42 PM
helldorado's Avatar
helldorado
I've used my infared thermometor to shoot the inside of the tips, black with carbon so not much reflection and seen temps upwards of 250-300 degrees.
Old Feb 27, 2008 | 12:41 AM
whitecel's Avatar
whitecel
Well tonight, I bought some vht high temp paint (up to 500 degrees). Trying a test pipe and misting it. Doesn't do the same job, but i think it might look good enough. Once everything is done, i'll post pics whether good or bad
Old Feb 27, 2008 | 01:05 AM
itsjiggajames's Avatar
itsjiggajames
I don't know about you, but yes I can touch them, but only for a split second. even after 2 hours.. but keep them on any longer I'll have bbq fingers.
Old Feb 27, 2008 | 01:28 AM
whitecel's Avatar
whitecel
hey guys,
Just FYI and those that have the same rusty tip as me. Apparently there is a way to make stainless that bluish tinge. All you need is a blow torch and make the stainless red hot. Let it cool, and it turns blue from the chemical reaction. Here's the link...Gonna try this tomorrow on a test piece first.
http://www.s2ki.com/forums/index.php...ic=356084&st=0
Old Feb 27, 2008 | 06:31 AM
Hydrazine's Avatar
Hydrazine
yeah its possible. And I even thought of suggesting it, but be careful... It may totally wreck your tips with warpage.
Old Feb 27, 2008 | 08:43 AM
whitecel's Avatar
whitecel
I think today I'm going to try it. I'll first practice on the x02 g35 extension just to get the feel for it. When I do the actual tips, I'll be careful since the tips are such thin metal
Old Feb 27, 2008 | 09:53 AM
Hydrazine's Avatar
Hydrazine
Thin metal warps real easy when a torch is involved.
