MD Plenum Spacer install problem
Old Feb 27, 2008 | 11:53 AM
Asian Invasian's Avatar
Asian Invasian
Originally Posted by gothchick
If it's idling rough, you have a plenum leak...
the thing is it definantly did not feel like this yesterday night when I know I had a leak.. the idle is a little rought but why does it feel like its struggling when i start out? Should I go try to tighten them more, i mean how much exactly is 100 inch lbs?
Old Feb 27, 2008 | 12:24 PM
Eazzy's Avatar
Eazzy
1)Read the instuctions from beginning to end,
2) get a torque wrench,
3) remove everything,
4) set everything in place so to assure all is in order,
5)blot the gaskets to remove oil etc.
6)check that spacers are installed with the concave facing up
those are held in place by the proper length bolts (instructions)
7)Permatex makes anti squeal spray for brakes and terminal spray for Battery terminals and spray sealant for gaskets. Buy any of the above and spray all gaskets
8) Re assemble (per instuctions)
9) torque (per instructions)
10) Install hoses (per instructions)
11) start vehicle
12)drive vehicle
Asian Invasian
Got it it was my strut bar, i don't know how it made my car feel like that but i took it off and its perfect.
Guess ill try to fix that later..
car pulls alot better MD FTW!
Old Feb 27, 2008 | 12:28 PM
Eazzy's Avatar
Eazzy
I guess i have to use the strut bar spacers? I thought that was only for the 1/2 plenums..
13) Install spacers under strut bar (per instuctions)
14) start vehicle
15) drive vehicle
Old Feb 27, 2008 | 12:30 PM
Eazzy's Avatar
Eazzy
13a) close hood
Old Feb 27, 2008 | 12:31 PM
Asian Invasian
14) start vehicle
15) drive vehicle
Thanks
Old Feb 27, 2008 | 12:32 PM
Asian Invasian
13a) close hood
uhhh it won't close, there is some kind of bar holding it up.. what should i do?
Old Feb 27, 2008 | 12:33 PM
lbz's Avatar
lbz
Highly recommend getting a torque wrench. Will come in handy for later projects. If you tighten the bolts too much you could crack the top of the plenum... not enough and you get leaks...
Old Feb 27, 2008 | 12:42 PM
Eazzy's Avatar
Eazzy
Refer to Instruction Manual .... Read.... Close cover ...Close hood
Old Feb 27, 2008 | 12:44 PM
06MagneticZ's Avatar
06MagneticZ
a common noob mistake when installing spacers is the rubber piece on your oil filler neck sometimes gets stuck between your plenum and spacer. THis will cause a leak and make your car run like ish....believe me I know. Dont ask!
Old Feb 27, 2008 | 12:46 PM
Eazzy's Avatar
Eazzy
How did you come by this information ?
Old Feb 27, 2008 | 12:52 PM
Asian Invasian
Its all good now
Old Feb 27, 2008 | 01:03 PM
06MagneticZ
lol...I am not at liberty to say
Old Feb 29, 2008 | 06:56 PM
misterlv's Avatar
misterlv
oh **** hahaha i so wanted to put in a spacer for mine too but you scaring me man. i dont want to anymore.
Old Feb 29, 2008 | 07:40 PM
HondaKiller's Avatar
HondaKiller
over compensating for the strut bar clearance can be painful when reinstalling it. it actually doesn't take much adjusting after installing the spacers. They can be tricky but just need to be lined up right.
For those who are scared, there are plenty of DIYs on the site along with a well laid out instruction manual. With the proper tools, extra set of hands and a little patients, it's a walk in the park. Heres my spacer install from a few months back.
https://my350z.com/forum/showthread....spacer+install
Glad to hear you got it worked out op.
Old Feb 29, 2008 | 07:47 PM
Asian Invasian
Dont worry I was just so impacient. There is hardly anything that can go wrong, just follow the instructions man.
Old Mar 5, 2008 | 10:00 AM
Yujimbo's Avatar
Yujimbo
I have a question. I recently got motordyne 5/16 iso thermal and when it is cold outside and I floor it the car hesitates then goes. It just started happening after the spacer was put on.
Old Mar 5, 2008 | 10:37 AM
  #38
dmroberson's Avatar
dmroberson
how cold is cold? I only had that problem when I forgot to open the CCV, and it was about 35 degrees outside. Once I did, no more problems. The manual suggests opening the CCV when ambient temps hit 55 degrees and below.
Old Mar 5, 2008 | 10:55 AM
  #39
Yujimbo's Avatar
Yujimbo
that sounds about right. it was about 40-50 degrees outside. So i need to close it when its cold right. I read the manuel but i had a shop put mine on and I dont know where the actual valve is... I know I know you dont have to call me retarded i already know. lol
Old Mar 5, 2008 | 11:07 AM
  #40
Eazzy's Avatar
Eazzy
HaHa Retarded---actually all don't have Valves, but check it
