HELP! Need pics of Turbo XS exhasut installed
Old Mar 14, 2008 | 09:37 PM
Mamounas123's Avatar
Mamounas123
Default HELP! Need pics of Turbo XS exhasut installed
I was installing my turbo xs exhaust today. Does anybody have any pics of the exhaust installed from underneath the car. I think i bolted the y-pipe to the mid pipe wrong because it rattles a lot and does not sound to good.
Old Mar 15, 2008 | 05:57 AM
68Stang's Avatar
68Stang
Tighten up your y to b pipe connection. Its rattling on the under brace. Use lock washers so the bolts don't loosen themselves and let it sag again. When you get under the car, push up on the section near the brace and place something between the brace and the exhaust to hold it up. Tighten the hell out of the bolts. Tap the object out from between the exhaust and the brace and you should be good to go.
Old Mar 15, 2008 | 06:06 PM
jdhuegel1's Avatar
jdhuegel1
Yup; has a tendency to sag and hit that damn brace. I heard somewhere someone added a hanger near that joint to hold it up... not positive though.
Old Mar 15, 2008 | 06:25 PM
DBTRACK's Avatar
DBTRACK
no problems with mine..... I have over 1" of clearance at the midpipe.
Just need to get under there and loosen everything up... and start from the front and crank it all back down with the midpipe resting on something to help support it while your tightening it all up. I did this and have ran the car hard and it has not moved a centimeter.
