Which "bung" do I screw the o2 sensor into on Berk cats?
I am going to install the cats within the next few days. Which "bung" does the o2 sensor go in? One sticks out of the pipe and the other one is flush with the pipe.
Originally Posted by gothchick
Hahaa. You said 'Bung' and 'Screw' in the same sentence~ Lol! :-)
I imagine the long one is the one that was designed for test pipes. It was designed to fool the o2 sensor into thinking there was a working cat installed when there isn't. Like the old spark plug fouler trick.
I think I should use the one that is flush with the pipe since I don't have to worry about a CEL with high flow cats.
There are instructions but they are for test pipe installation. The install process is the same but with test pipes you definately want to use the long bung. That I am sure of. The extra bung is for an aftermarket wideband o2 sensor. Since I have an 05, which comes stock with wideband o2 sensors, I will only be using one bung.
I called Berk but the receptionist said the guy who could answer that question is on vacation.
I did the same thing and called Berk. Same answer....Everyone that can answer the question won't be back until next week. She recommended sending an e-mail to info@berk. I guess we'll see how responsive Berk is.
You'd think they would provide specific instructions with the HFCs, not just throw in directions for test pipes. Nobody does their job.....
I've seen Bryan from Berk post in another thread that with HFC's you should just hook it up to the bungs that are flush with the pipe, like stock. I was thinking of putting them in the non-fouler location so that they last a little longer, but will it affect the way the car runs then?
Yeah, my cats arrived at Berk today to be fixed/replaced, and now Bryan is out of town
Must be at a show or something.
I think it could slightly affect the way it runs because it won't be getting a fully correct reading. That is the reason Berk uses the long bung for test pipes. It limits the amount of exhaust the o2 sensor "sniffs". That could affect the way the car runs. I would imagine it would have a greater impact on cars with the stock wideband o2 sensors.
The more I think about this I am almost positive the bung that is flush with the pipe is the correct one to use.
Originally Posted by Tac-M
^ that is the correct hole ! they are almost like TPs , there is a nonfouler built-in, so that we don't get an CEL ( ha ha teepee LOL )
Well, it appears 50% of the time, the sensor is installed in the front/flush bung and 50% in the rear/protruding bung. Neither front or rear appear to create a problem with a check engine light.
I going to wait to see what Berk has to say and I'll post their response.
Originally Posted by davidv
Agree. Its kind of like a built-in non-fouler. The other port may be used for a air:fuel gauge.
This has been acknowledged by Berk and I believe you can special order them from Berk with a A/F bung before the catalyst.
Yes, but with high flow cats you shouldn't get a CEL. Even without a nonfouler.
My Power Enterprise 400 cell mettalic HFC's threw a cel on my 05 g coupe after 50 miles. Non-fouler fix worked.
New model years are getting tougher to trick due to stricter federal emission requirements.
