Pop Charger without heatshield
Old Jun 21, 2008 | 06:45 AM
OCG35's Avatar
OCG35
Originally Posted by davidv
The most troubling threads always begin similar to this.
especially when intake temps where thought to be measured by the coolant temp gauge in the instrument cluster... I would have hoped the “experienced tech” would correct the misunderstanding.
Old Jun 21, 2008 | 06:50 AM
OCG35's Avatar
OCG35
Originally Posted by Hoooper
too bad nobody ever seems to test in motion, since when youre moving the air around the engine is pretty close to exterior temps.
case in point: go take your cold car, go WOT several times while driving for like 5 mins, then feel the intake manifold. its still cold. only when you let the heat from the heads creep up into the intake manifold does it make a difference. with my phenolic spacers, i drive home from work, hit traffic and probly average about 15mph on the way home. when i get there the intake manifold is still cold. if the air in the engine bay was hot when in motion, the intake would be hot after driving even though it didnt transfer through the phenolic. there ARE differences with the heat shield even when moving, but theyre small. you really wouldnt notice unless youre stopped or on a dyno where its obviously not a moving test.
the point: if you have them use them, but if you dont have them it doesnt matter
when you're staging at the drag strip there is a lot of stagnant hot air... same with sitting at a red light needing to get over for a fwy on ramp... I don’t think anyone would argue thermal management as being a big power factor - but as with most mods it’s a combination of things that help.
I wouldn’t run without a heat shield (or some of the other thermal things I’ve done).
07ZEKE
Aug 23, 2021 09:15 PM
_bit
Oct 2, 2015 07:49 AM
B Esquire
Sep 24, 2015 07:52 AM
