Exhaust Question
Old Jun 16, 2008 | 12:17 PM
Zero350z's Avatar
Zero350z
Default Exhaust Question
I want to get the helix v2 test pipes and put them on my stock 03 exhaust, does it bolt right on and should i get a new y-pipe with it or is the test pipes fine on the stock exhaust, thanks
Old Jun 16, 2008 | 01:06 PM
singh's Avatar
singh
_______________
Those test pipes are compatible with any aftermarket exhaust made for the 350z. They can mate with the stock exhaust also. You are absolutely fine.
Old Jun 16, 2008 | 01:36 PM
Zero350z's Avatar
Zero350z
thanks and also should i get a y-pipe with it or just get the testpipes only?
Old Jun 16, 2008 | 03:01 PM
singh's Avatar
singh
_______________
It's your money I don't care what you get. In my opinion, I would just keep the stock y-pipe. If you swap out only the y-pipe, you will recieve little to none horsepower gains. And it will sound almost exactly the same.
If you plan to have an all-out performance-oriented Z, then I would swap out not only the y-pipe but also the rest of the exhaust.
It all depends on how much money you are willing to incorporate into your car.
Old Jun 16, 2008 | 04:08 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I did testing of the stock Y-pipe on an otherwise high performance exhaust system and found that it dropped about 6 HP.
I was surprised at the results to say the least.
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
