Dose X-pipes remove RASP
Old Jul 2, 2008 | 11:26 PM
Darkness75's Avatar
Darkness75
Originally Posted by tranceformer95
headers + testpipes + FI 2.5" true dual = no rasp
I'm gonna guess the Magnaflow x-pipe muffler helps a lot with this setup.
can you post a vid-clip
i need to see a comb that gives no RASP
Old Jul 3, 2008 | 03:10 AM
tranceformer95's Avatar
tranceformer95
i don't have a clip of my own car but there's plenty posted already. IIRC there should be some on their website.
Old Jul 7, 2008 | 02:16 PM
SamH's Avatar
SamH
I currently have the Borla TD exhaust and have purchased the Magnaflow Xpipe/muffler. When I took it to the exhaust shop, it didn't fit where the H pipe was. They said I would have to flare the piping.. Is this true?
Old Jul 7, 2008 | 03:15 PM
pimpin714style's Avatar
pimpin714style
Originally Posted by gothchick
I did a custom fabbed x-pipe on my HKS. No rasp.
how much would your friend charge to customize another one?? same setup.i could use that.most muffler shops get under my car take a look and dont wanna touch it.
Old Jul 8, 2008 | 07:15 AM
Darkness75's Avatar
Darkness75
wich one did you get ?
i have sent 3 e-mail`s to magnaflow askking them which one will fit on my APS 2.5" TD exhaust , NO REPLAY until now
any body knows ??
Old Jul 8, 2008 | 07:43 AM
The Captain's Avatar
The Captain
*Edit* fail on my part. Didn't realize you were talking about APS 2.5" exhaust.
Old Jul 8, 2008 | 08:50 AM
Jeff92se's Avatar
Jeff92se
Magnaflow might not be able to answer. 2.5" is a nominal measurement. ID/OD measurements will be different depending on the guage used for the pipe. You have to actually measure the exact id/od of the pipes you have and the pipes you want to use. ESPECIALLY if it's a slip fit like the Borla.
If it's just a cut/weld, it doesn't have to be exact but it would help it flow better.
Old Jul 8, 2008 | 07:23 PM
SniperHunter's Avatar
SniperHunter
Attachment 197959
Attachment 197960
any body knows ??
I believe pic #2 is correct for Borlas. Someone needs to confirm that.
Old Jul 9, 2008 | 01:33 AM
Darkness75's Avatar
Darkness75
well thats how my APS exhaust look like from down under :
i think the X-pipe that go`s with it is that one :
DESCRIPTION: Material: 100% Stainless Steel
Inlet/Oulet Size: 2.5in Dual/2.5in. Dual
Overall Length: 9.5in.Core Size: 2.5in.x4in.
Don`t you think guy`s ??
is magnaflow are known for ignoring customer Q`s and e-mail`s
i`m having second thoughts about ordering from them
Old Jul 9, 2008 | 06:18 AM
The Captain
I don't believe that is the correct one. The part for my Borla was
Product ID: MAG11385
Product Name: 11385
http://www.performancepeddler.com/de...CT_ID=MAG11385
This place had it a lot cheaper than the others that I checked. (Most were $110+)
Old Jul 9, 2008 | 09:19 PM
SamH's Avatar
SamH
Default above
the above image is the correct version of the magnaflow xpipe that I purchased... there was a discrepency with the ID/OD
Old Jul 10, 2008 | 07:27 AM
SniperHunter
Product Name: 11385
I always thought it was that one, but lately people have been posting pics of the X-pipe above, so I got confused. Thanks!
Old Jul 10, 2008 | 07:57 AM
The Captain
Np. And, yeah, people usually post those same pics of those other two X-pipes, so it's very confusing trying to find the right one. It took me a quite a bit of reading through pages of old threads to find someone who had the part number posted. After I found it, I made sure to save it in my e-mail so I could help out anyone else who asks about it.
Old Jul 16, 2008 | 12:53 AM
Darkness75's Avatar
Darkness75
still i didn`t find any body in magnaflow or APS or any place else to tell me which X-Pipie would work with my exhaust (the APS 2.5 TD) ,,,, !!!!
i wish there was a Tony or Bryan in every company
Old Jul 25, 2008 | 05:16 AM
350Zenophile's Avatar
350Zenophile
Anyone have pics of the magnaflow x-pipe muffler installed? Is this something that would have to be cut out to drop the tranny?
Old Jul 25, 2008 | 07:38 AM
rcdash's Avatar
rcdash
Look at any FastIntentions exhaust for an example. Why on earth would you have to cut it out to drop the transmission? The exhaust piping runs on either side of the trans with plenty of clearance. The X pipe muffler is inserted at a point distal to the transmission (below the driveshaft) where the pipes run close together.
Old Jul 25, 2008 | 10:18 AM
Darkness75's Avatar
Darkness75
thanx for your replay .
but as you see there is two kinds of X-Pipes ^^ ,which one should i take ?? thats my Q
Old Nov 10, 2008 | 12:39 PM
  #38
BrianLG35C's Avatar
BrianLG35C
Did you ever go with an x-pipe? Which one and how does it sound?
Old Nov 10, 2008 | 10:55 PM
  #39
Darkness75's Avatar
Darkness75
no i didn`t , and i went back to stock exhaust because of RASP , Drone and loss of power = TD + 2.5" + N\A = bad performance and sound ( just me and what i think)
Old Nov 11, 2008 | 07:28 AM
  #40
SamH's Avatar
SamH
The X-pipe greatly reduces the rasp though and adds a bit of backpressure which is needed if you're n/a and running 2.5'' dual ex. w/ a Magnaflow x-pipe I picked up 5whp w/ my Borla exhaust.
