Best test pipes
Old Aug 5, 2008 | 09:25 AM
D_K's Avatar
D_K
Default Best test pipes
Anyone had any problems with their Megan Racing Test pipes ?
Also wanted to know if pretty much any test pipes out there (minus the ebay garbage) will bolt on to the stock Y pipe ? (I'm aware the diameter should be the same or close to as the stock y pipe but was wondering if depending on the diameter if the holes for the bolts would matchup)
My other question is ; are test pipes universal throughout 2003-2008 models ?
MUCH THANKS !!
Old Aug 5, 2008 | 10:03 AM
Kingofvacuity's Avatar
Kingofvacuity
Megans are known to crack fairly easily.
Oh and not all all universal 07-08 are different from the 06 and down.
Old Aug 5, 2008 | 10:32 AM
D_K's Avatar
D_K
Got any links for 2007-2008 models ?
Old Aug 5, 2008 | 10:34 AM
Legr19's Avatar
Legr19
Old ones did, i've heard no complaints about the new ones with the flex pipe, which are the ones i'm using and have had no problems so far.
Old Aug 5, 2008 | 10:37 AM
Phreakdout's Avatar
Phreakdout
Where do the Megan's crack? I have a pair on w/o the flex and they are doing ok.
Old Aug 5, 2008 | 10:40 AM
• Regardless of the inner diameter, the holes and bolts will line up.
Old Aug 5, 2008 | 10:41 AM
OldDirty Z33's Avatar
OldDirty Z33
I would assume the flanges will crack... i have a full 3'' exhaust on my gsx and over a year now and it hold up.... many awd launches
Old Aug 5, 2008 | 10:50 AM
t-350z's Avatar
t-350z
get the aam test pipes for the 07. www.z1auto.com carries it. I just got them on today and im very happy with the setup. Going to get a y pipe next.
Old Aug 5, 2008 | 10:53 AM
D_K's Avatar
D_K
Thanks, did they come with a warranty ?
Old Aug 5, 2008 | 11:14 AM
D_K's Avatar
D_K
Yeah I wasnt sure about Megan , I purchased a catback from them two years ago for my 97 Eclipse and it said that it was made in cambodia or some third world asian country , maybe thats why their stuff is so cheap ? Anyways I didnt have a problem with the exhaust but ever since I just felt I dodged a bullet.
Old Aug 5, 2008 | 11:22 AM
D_K's Avatar
D_K
did you run it through a dyno to see the difference in power ?
Has it affected your MPG ?
Old Aug 5, 2008 | 11:48 AM
t-350z's Avatar
t-350z
not yet i just got them today. i havnt really gotten on it so i dont know about the feeling more power. Not sure about the warranty.
Old Aug 5, 2008 | 02:29 PM
Kingofvacuity
You should just take a look at the classifieds..there are quite a few sponsors selling TP's for that year.
Old Aug 6, 2008 | 05:54 PM
D_K's Avatar
D_K
How easy were they to install ?
Old Aug 6, 2008 | 07:57 PM
t-350z's Avatar
t-350z
i had my shop do it but the hassle was the 02 sensor. They said it was screwed on to tight from the factory and they stripped it trying to take it out. So the guy re-threaded it.
Old Aug 6, 2008 | 08:09 PM
05Z33's Avatar
05Z33
In reference to "ebay garbage". I've had My $50.00 ebay garbage test pipes for 3 years without any problems at all.
Old Aug 6, 2008 | 08:48 PM
Phreakdout's Avatar
Phreakdout
This is where I got my resonated test pipes. After shipping and all, they were just a tad over $100. The flanges look like they were CNC machined. All of the welds we auto rotary TIG welds. (Not hand welded) I had no issue with quality. They were not advertised as Megan Racing parts, but I can tell that they are from the same factory.
These are pretty easy to install. Jack the car up enough to get some working room. You will need a few long extensions and two U-joints on the socket wrench. You loosen the 4 of the 6 OE flange bolts from inside the engine bay. The remaining two are loosened from under the car.
When you install the new pipe, you get a complete set of bolts and gaskets. Now you can tighten all the bolts from under the car using a wrench and a socket set.
As for the O2 sensor, remove the OE converter with the sensor still attached. Place one end the OE converter flanges into a vice to hold the assembly still. Use penetrant spray on the O2 sensor. Wrench the O2 off now. If it will not budge, then use a propane hand torch to warm up the O2 fitting on the converter. (So it expands) Don't apply the heat to the O2 sensor directly. It should be easier to remove now.
This is easy enough that you don't need to take it to a shop. If the shop agrees to $30 install charge, then you might want to consider it. LOL
Old Aug 6, 2008 | 10:04 PM
killa.beez33's Avatar
killa.beez33
im content with my strup test pipes. are you going to put them on your stock exhaust?
Old Aug 6, 2008 | 11:43 PM
Helix SS Test Pipes. 18,840 miles and still in one piece (knock on wood).
Old Aug 7, 2008 | 05:25 AM
gothchick's Avatar
gothchick
Almost 20k miles on my Kinetix resonated TPs, with extra bungs welded in for dual widebands. Holding up perfectly. Plus they come with a lifetime warranty, which I doubt I'll ever need to use... :-)
