Hi flow cats
Old Aug 18, 2008 | 08:15 AM
Bigchef66's Avatar
Bigchef66
Default Hi flow cats
Simple question;
Do hi flow cats give the same the rasp you get with test pipes?
Old Aug 18, 2008 | 08:16 AM
Z04's Avatar
Z04
simple answer. no
Old Aug 18, 2008 | 08:26 AM
Bigchef66's Avatar
Bigchef66
Originally Posted by Z04
simple answer. no
thank you sir
then I need a set of hi flow cats....
Old Aug 18, 2008 | 10:32 AM
Yes. But beter.
Old Aug 18, 2008 | 11:02 AM
2fast4ya's Avatar
2fast4ya
i have metallic hi-flo cats in my z, they have a tinny/tuner type sound
to them.
fast intentions is the brand, i was happy with the performance gain, just
did not like the sound
Old Aug 18, 2008 | 11:19 AM
WTX350Z's Avatar
WTX350Z
Kinetix HFC's here, they have some rasp in upper RPM's. I honestly thought it was exhaust leak, but Can't find a leak anywhere. Might R&R them with all new gaskets when I do a Catback just to make sure though...cause its slightly irritating. Seems like the hotter the day the less rasp (once the car is fully warmed up).
Old Aug 18, 2008 | 01:42 PM
PFunk124's Avatar
PFunk124
Currently using Stillen HF cats. Gains about 5-12 HP depending on mods on you car. The CATs sound great at load RPMs. None to very little rasps at high RPM's.
Also the check engine light doesn't come on and i dont smell gas when I'm at a stop which you get from test pipes.
Old Aug 24, 2008 | 11:24 AM
Zed Zed R 07's Avatar
Zed Zed R 07
I have the Stillen HFC on my 07 with Stillen exhaust and Fujita dual intakes...the Check engine light is on as a result of the cats. Will use the plug foul solution from this site to fix but wonder why my light is on if your's is not??
I like the sound...very little rasp and +1 on no gas smell.
Dumb question - have you reflashed or gone to a fuel mgmt system (if there is one for an 07)??
Thanks for any input!
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
