O2 sensor problems
Old Aug 28, 2008 | 07:32 AM
bswanny's Avatar
bswanny
Default O2 sensor problems
Does anyone know how having a SES coded P0420 (cats opperating below efficency) effect how your engine will run, more importantly the A/F mixture.? Do people just run there car with theses CEL and have no problem?
Old Aug 28, 2008 | 08:50 AM
HondaKiller's Avatar
HondaKiller
probably wont affect anything except gas milage, but yes it will affect your A/F.
Old Aug 28, 2008 | 09:53 AM
bswanny's Avatar
bswanny
Do you by chance now how much of a difference it make on your A/F ratio? Enough to run lean or rich?
Old Aug 28, 2008 | 11:43 AM
HondaKiller
I can't say how much for say as in if it will change your ratio, biggest difference is going to be the 2-3 mpg you start losing. If it leans your car out which is possible, listen of detonation ping up in the higher RPMS. Over and above you should be fine untill you replace, but dont take that to the bank. Replace as soon as you can, dont hold off because you think "it wont do much" One thing leads to another untill you have a domino affect of **** piles dropping on your car.
Old Aug 29, 2008 | 06:43 AM
bswanny's Avatar
bswanny
So do people just drive around with the CEL and not have any problems? I have a code P0420 and tried everything and cannot get it to go away.
Old Sep 3, 2008 | 07:59 AM
bswanny's Avatar
bswanny
Bump for a ray of hope?
Old Sep 3, 2008 | 08:01 AM
rcdash's Avatar
rcdash
You will not pass emissions testing in most states with a CEL. You could get an Osiris reflash to eliminate the CEL. Or just buy the less expensive Cipher and clear the code as needed. Or get aftermarket cats. Or pick up stock used cats for cheap in the marketplace. Lots of options!
Old Sep 3, 2008 | 01:12 PM
bswanny's Avatar
bswanny
I have after market cats and tried the anti-fouler trick and checked for leaks, ect. and still cannot get that code to go away
Old Sep 4, 2008 | 12:01 PM
bswanny's Avatar
bswanny
Has anyone solved the CEL for HFC on 2004.5 and Later 350Z's? I tried the anti-foulers and still didn't work. Please any ideas?
Old Sep 4, 2008 | 11:10 PM
infinite's Avatar
infinite
Why do you have an aftermarket cat? are you racing sir ? (officer hardass)
Old Sep 6, 2008 | 12:51 PM
bswanny's Avatar
bswanny
What?
Old Nov 13, 2008 | 08:33 PM
coolbratva's Avatar
coolbratva
I have the same problem and I was told it could be the o2 sensors i changed all four of them and still the light is on. Also my rpms are not stable when you put it in neutral from 6th gear, almost like its about to stall for few seconds and then the needle jumps back to normal, but sometimes it stalls if was pushed hard in 6th gear and then put in neutral.
Old Jan 20, 2009 | 11:05 PM
SS21CA's Avatar
SS21CA
I have that same problem!!! no CEL. Dealer told me one of my o2 sensors is bad recently, but I think it is unrelated.
I've had this problem for 3 years now!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
