Modified Borlas, please enter!
Old Sep 30, 2008 | 08:12 PM
Aced16's Avatar
Aced16
Default Modified Borlas, please enter!
Well i am heading home this weekend and decided while i am there, i am going to get my Borla welded (to deal with those annoying leaks) and get the H pipe removed and add an X and or a muffler there. my question is, is it best to add an X like so...
http://cgi.ebay.com/ebaymotors/MAGNA...mZ330274609820
or and actual muffler like this...
http://cgi.ebay.com/ebaymotors/MAGNA...mZ260292659323
I dont know much about back pressure but i do know that some is needed when NA and i thought by adding a straight muffler like that i would lose BP sorry kind of a newb at that lol
also what about this option (since is does incorporate a cross flow)...
http://cgi.ebay.com/ebaymotors/Flowm...mZ130252676801
Any help would be grateful, and if you guys have any sound clips of your modifies Borla's i would REALLY appreciate it. thanks in advance!
Also 2.5in piping is fine right, or should i go 2.25?
Old Oct 1, 2008 | 05:21 AM
ingramstar01's Avatar
ingramstar01
I would go with the Magnaflow X-Pipe muffler in 2.25" as I believe those who went with just the X-Pipe said the rasp was an order of magnitude WORSE.
I've added the above part to my Borla TD and have been very pleased with the results. My original reason for swapping out the H-Pipe was due to the rasp generated by my metallic HFCs but the car did seem to pick up a tiny bit of performance as well.
As far as the straight through muffler/resonator goes you will probably eliminate your rasp but you'll likely lose some low to mid-range torque as well (this is an educated guess, so if someone knows better please feel free to chime in).
Old Oct 1, 2008 | 06:05 AM
meaj82's Avatar
meaj82
I have the 11385(magnaflow x-pipe muffler) on my borla along with headers and testpipes for about a year now and have been very pleased. No rasp and a bit of added low mid range grunt is back that was lost when I first added the TP. Most people dont realize I have a full after market ehaust (header back) due to how how nice and tame it sounds.
here my thread with a video and some pics in another link:
https://my350z.com/forum/intake-exha...ow-x-pipe.html
Hope this help you out.
Old Oct 1, 2008 | 07:46 AM
Aced16's Avatar
Aced16
^ that sounds AMAZING! i just ordered mine from summit and will have it friday and installed on sat! i cant wait, thanks for the info ALL!
Old Oct 1, 2008 | 08:45 AM
WTX350Z's Avatar
WTX350Z
If I have any rasp w/ my new exhaust I'm getting that Magnaflow xpipe muffler.
Old Oct 8, 2008 | 06:20 PM
ZAW117's Avatar
ZAW117
How's the fitment of the Magnaflow muffler? Can the pipes on the TD just be cut and the Mag welded in without any mod?
And for you header gurus, what header would be the best setup with my TD/Mag combo? Thanks.
Old Oct 8, 2008 | 08:05 PM
SniperHunter's Avatar
SniperHunter
None of those will work. Only Magnaflow 11385 will.
Old Oct 8, 2008 | 09:08 PM
krivera6950's Avatar
krivera6950
can you use the magnaflow 11386 which is 2.5in. instead of 2.25?
Old Oct 9, 2008 | 10:16 AM
WTX350Z's Avatar
WTX350Z
If your exhaust is 2.5in in diameter that should be the correct one AFAIK.
Old Oct 10, 2008 | 06:10 AM
meaj82's Avatar
meaj82
Yeah, just take it to a muffler shop and they can cut out the h-pipe and weld in the magaflow right on. Took my guy about 15-25 mins. I have topspeed and have been very please. Check out strup's headers.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Tochigi_236
Sep 27, 2015 03:40 PM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
