Keep the popcharger? Opinions please.
Old Oct 4, 2008 | 09:48 AM
Spork's Avatar
Spork
Alright, so far I've gathered that there will be little difference, if at all, and the extra incoming air can help cool the popcharger and heatshield along with ambient areas.
More opinions?
Old Oct 6, 2008 | 11:13 PM
terrasmak's Avatar
Originally Posted by Silverstone-Z
I don't want to spend money
The thing is... With the extra incoming air, would it dissipate the heat enough to make no difference between the stock airbox and the popcharger?
It won't make much of a difference when the car is moving. For some odd reason many people do not understand what the heat soak actually does, and when it happens. Heat soak occures on these cars when its sitting still, and goes away within a minute of the car being in motion.
That duct will help a little, maybe take 10 seconds off the normal cooldown.
The big problem that people think is heat soak is actually when you run without the popcharger heat shield. Your car is drawing hot air at all times. If i remember correctly there is a 75+ degree difference in running with and without the heatshield, and less than a 10 degree difference between a popcharger and stock intake.
Old Oct 7, 2008 | 07:45 AM
importpunisher's Avatar
importpunisher
I know this should be in the Intake/Exhaust subforum, but I'm simply looking for opinions, and I assumed this would be the best place to get as many opinions as possible. So mods, if it's alright, I'd like to ask you to keep this thread here unless you really insist on moving it.
Onto the thread material...
So I ended up moving from my stock 03 airbox to the Popcharger.
I will admit, I wasn't looking for significant gains. I was more looking for something that looked neat, and the loss or gain of ~2whp was really not of my concern.
However, I recently changed from the stock front bumper to the Nismo V2 with the intake vent that directs incoming air from the bumper's opening up to the intake hole.
Will this increase of incoming air keep the heatsoak on the Popcharger from being an issue? Or should I go back to the stock intake?
I know the popcharger has heatsoak issues, but the intake ducting could prove to lead more cool air up to the filter and essentially cooling off the filter and areas, ultimately bringing the ambient temperature down.
With this in mind, is it worth going back to the stock airbox? Or will the extra incoming cool air give me the same results with the popcharger, if not better, than the stock airbox being reinstalled?
Opinions, criticisms, and simple input is very much appreciated.
Thank you.
Some pics of the stuff in case anyone needs a clearer picture of what I'm talking about. You can see I've enjoyed the extra eye-candy the popcharger includes, so I changed the look of the heatshield .
The picture of the V2 intake duct is next.
i use this air filter with my injen intake
http://www.amsoil.com/storefront/eaau.aspx
Old Oct 7, 2008 | 07:50 AM
importpunisher
Does the bottom most vent sit directly above the filter?
From the picture in my head... it'd sit right in front the vent. I''ll do some searching.
my buddy as this hood and the same intake set up as me and the filter does NOT sit right under the last vent, so he can and does drive in the rain. but im not sure were the popcharger sits.
Old Oct 7, 2008 | 07:58 AM
WTX350Z's Avatar
WTX350Z
Originally Posted by importpunisher
based on the pics I'd say the PC is located infront of the first vent, but after the hood pin.
Old Oct 7, 2008 | 08:04 AM
tranceformer95's Avatar
tranceformer95
To be honest, I wouldn't really worry too much about it. It's peanuts compared to the other parts of the car that can be changed.
Old Oct 7, 2008 | 02:26 PM
gothchick's Avatar
gothchick
I sold my pc cuz teh heat soak was getting on my nerves. went back to '06 intake. much more consistent in stop & go, yo.
Old Oct 7, 2008 | 03:31 PM
aggietsi's Avatar
aggietsi
Happen to know of anyone locally with something like AutoEnginuity? (Not sure if Cipher does it). AE logs intake temps in real-time. It'd be easy to swap between intakes and see temps at idle, low rpms, and high rpms. Should log airflow, too. You can see if one actually frees up any power.
Old Oct 12, 2008 | 09:57 PM
OldDirty Z33's Avatar
OldDirty Z33
Just wanted to bump this for information for me. I'm a torque guru and want to keep all the torque I can. My plans for my intake setup would be a stainless steel pipe or titanium pipe with the stock06 box/K&N filter with a Varis air duct. I don't want any heat soak problems because of my car being my DD. Is this ideal for my N/A set up or should I just go with the JWT pop charger???
I was also thinking about making a Aluminum Air box kinda like the ARC one. This guy said he will build me a legit aluminum box for 100$... Maybe build my own intake box with custom vent/cooler/tube going to the box??? kinda get my drift?
Old Oct 13, 2008 | 10:41 AM
OldDirty Z33
I just made my own thread thanks
Old Oct 13, 2008 | 12:29 PM
importpunisher
i would go with a custom set up that no one has.
Chris350z03
Oct 8, 2023 07:19 PM
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
juang20
Intake
Sep 7, 2015 05:37 PM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
