Question about my exhaust Setup Fuji exhaust/JIC y-pipe
Old Nov 19, 2008 | 08:16 AM
neo_rambo's Avatar
neo_rambo
Default Question about my exhaust Setup Fuji exhaust/JIC y-pipe
I noticed that I have rasp at high rpms on this setup doing further research I found out that the JIC Y-Pipe has Inlet Diameter: 60mm (2.36") and a Exit Diameter: 80mm (3.15") My fujitsubo exhaust has a 3.0 diameter. I thinking the y-pipe is causing the rasp and turbulence. Am I right? What is the diameter of the stock cat outlet? Would the rasp go away if I get a fuji y-pipe or megan. I searched for a solution didn't find anyone with the same problem. BTW Tanabe is not the best Y-pipe stated in that sticky up there. Its only a Inlet Diameter: 60mm (2.36") and Exit Diameter: 70mm (2.75") That would rasp holy hell.
Old Nov 19, 2008 | 06:21 PM
kramykram's Avatar
kramykram
do you run test pipes??
Old Nov 19, 2008 | 08:30 PM
Ztrackman's Avatar
Ztrackman
Test pipes and RT cats will rasp with that setup. I switched to Crawford cats and rasp is gone.
Old Nov 19, 2008 | 10:35 PM
jammin's Avatar
jammin
a friend of mine has fuji exhaust w/ jic ypipe and fast intentions RTP on his g35, and theres no rasp. sounds pretty nice imo
Old Nov 20, 2008 | 05:45 AM
neo_rambo's Avatar
neo_rambo
I don't have test pipes, I have stock cats, and stock headers. For the exhaust sorry I wasn't specific I have the Fujitsubo legalis R
Old Nov 20, 2008 | 07:32 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
perhaps you have an exhaust leak
Old Nov 20, 2008 | 09:25 AM
neo_rambo's Avatar
neo_rambo
I thought that too, I checked all my bolts and gaskets and everything looks tight. Sounds like a Rattly RASP at high RPM.
Old Nov 20, 2008 | 12:28 PM
Road Warrior's Avatar
Road Warrior
put it up on a lift and check it out...could have a crack somewhere too
Old Nov 21, 2008 | 05:57 AM
neo_rambo's Avatar
neo_rambo
I will check it out this weekend. So the difference in size in the y-pipe outlet and the exhaust inlet won't cause rasp?
Old Nov 21, 2008 | 05:07 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
It depends on how much of a difference in diameter there is.
A contraction of 3.15" to 3" isn't the cause. That's much too small of a difference.
Old Nov 22, 2008 | 07:57 AM
Rasp is overrated. Learn to love it. Its your friend.
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
