Independent Dyno Testers Needed!
Old Dec 15, 2008 | 07:32 PM
  #41
Ed 718's Avatar
Ed 718
BRAVEHEART
Originally Posted by OldDirty Z33
Are those over lays on the rear reverse lights?
Yes they are Blue Bat overlays.
Old Dec 15, 2008 | 07:41 PM
  #42
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Nice! hey can we get some pictures of the whole back part with both exhaust showing maybe 10 feet behind the car. I yet to see it full view. I would love to have one.
Also other mods on the car?
Is that with the single Harakni exhaust or dual?
That is the Harakiri single.
Keep in mind that the Harakiri single muffler is also interchangeable with (or part of) the dual system too.
Exact same look and parts interchangeable among the single and dual.
More pics will follow a little later but its not my ride so I don't know all the mods on the car.
It could probably use a reduction in spark timing by 4-5 degrees but the car is otherwise in perfect condition.
Old Dec 15, 2008 | 07:43 PM
  #43
Ed 718's Avatar
Ed 718
BRAVEHEART
I have more pics to add which I will do shorty once I get my camera bag out of my girlfriends car.
Old Dec 15, 2008 | 08:06 PM
  #44
OldDirty Z33's Avatar
OldDirty Z33
Nice! OMG Santa I been a god boi!
Old Dec 15, 2008 | 08:14 PM
  #45
2004Black350z's Avatar
2004Black350z
Exhaust Whore
sound clips yet?
Old Dec 17, 2008 | 02:03 AM
  #46
terrasmak's Avatar
Originally Posted by Get_Zwole
i still have yet to see pics of the single harakiri? except for the teasers is it ready yet?
Well my car is kinda dirty , well really freaking dirty, but i installed it soon after i got home from work.
The sounds i fantastic, i couldn't be happier. Nice tone, NO RASP at all , very deep and mildly aggresive. I may try to wake it up slightly with the straightpipe instead of the resonator at the end of my XYZ pipe.
Attached Thumbnails Independent Dyno Testers Needed!-dsc02704.jpg   Independent Dyno Testers Needed!-dsc02708.jpg
Old Dec 17, 2008 | 07:29 PM
  #47
cubanl81's Avatar
cubanl81
thats the single shockwave right
Old Dec 17, 2008 | 08:30 PM
  #48
Hydrazine's Avatar
Hydrazine
That's a "Gamma" shown in the picture.
The Shockwave Ti uses only a straight pipe from the axle back.
Old Dec 18, 2008 | 11:24 AM
  #49
OldDirty Z33
"Gamma>?"
Old Dec 18, 2008 | 01:49 PM
  #50
Hydrazine's Avatar
Hydrazine
Yes. There will be too many variations to not give them different names.
Old Dec 18, 2008 | 02:53 PM
  #51
OldDirty Z33
So thats a gamma and the Harakiri is the color Ti version. Same design- different color -different names. right?
Old Dec 18, 2008 | 03:35 PM
  #52
Hydrazine's Avatar
Hydrazine
Yes, but slightly different sound too.
Old Dec 18, 2008 | 05:57 PM
  #53
OldDirty Z33
OOOOOOOOOOOOOOOOOOOOOOOOOooooo I get it now. I actually took my time and checked both of them out.
Old Dec 22, 2008 | 09:44 PM
  #54
Hydrazine's Avatar
Hydrazine
Originally Posted by 2004Black350z
sound clips yet?
Here you go Sir!
This is Unluckycharms dyno comparison of the Fast Intentions Intimidator and the Motordyne Gamma Dual Exhaust on a 2007 6MT G35C.
Reference: http://g35driver.com/forums/intake-e...-setups-7.html
DYNO DATA:
Fast Intentions - Fine dash line
Motordyne - Heavy dash line
RUN 1
RUN 2
RUN 3
RUN 4
RUN 5
RUN 6
Fast Intentions Dual Sound Clip
http://s352.photobucket.com/albums/r...FIG35Sound.flv
Motordyne Gamma Dual Sound Clip
http://s352.photobucket.com/albums/r...MDG35Sound.flv
Old Dec 22, 2008 | 10:01 PM
  #55
Rickdogg's Avatar
Rickdogg
Out of hiatus
Nice gains over another aftermarket exhaust. Here is a list of his modifications for those that are lazy to click on the G35driver link
Originally Posted by unluckycharms
The Detailed Write-up:
Intake/Exhaust set-up (tint and suspension excluded):
-Stillen intake
-Z tube
-Motordyne 5/16" spacer
-Motordyne MREV2 lower plenum
Previous Exhaust: Fast Intentions Intimidator Exhaust
New Exhaust: Motordyne Gamma Dual
Reason for switching: Modding ADD
Build Quality: Both exhaust systems are top notch in build quality, and fit up quite easily. The Motordyne favors V-band clamps where possible, while the Fast Intentions uses flanges. The clamps do allow rotation to be factored into the adjustability, but again, I had no issues with the fitment of either. All the welds appeared solid and clean.
The Looks: The exhaust looks very similar to the HKS exhaust, sans the resonating chambers on each muffler. The tips stick out from the car noticeably more than the FI exhaust, and do allow for adjustability. I will see if i can get the tips tucked a little further into the bumper, like my FI was.
The Sound: This exhaust sounds surprisingly similar to the Fast Intention, but a little bit louder, and with some mild high pitch overtones. I'm getting reasonable cabin drone from about 2000-2800 rpm, which I'm hoping will go away once the exhaust is broken in. I should have over 1000 miles on it by next weekend, so I'll try to report back on this item. If the drone doesn't go away, the next plan of attack is to swap in a resonator behind the Y-pipe.
The Performance: Before we slapped the car back on the dyno, we took a quick spin around to make sure all was well. I noticed that the car was a little smoother coming off idle, but otherwise performed very similarly to the FI. The dyno plots (below) confirmed that I had gained back some low-end torque (likely due to the Y-pipe configuration), and made very slight gains over the majority of the powerband. After driving the car for a couple days, the torque is still noticeable, but I'd say the butt dyno reads about the same everywhere else as the FI exhaust.
Dyno Type: Dynapack
# of Runs: 6 pulls with each system (4th gear)
Ambient temperature for FI dyno: 59 degrees
Ambient temperature for Motordyne dyno: 57 degrees
Old Dec 24, 2008 | 07:12 PM
  #56
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Waiting on Sound clips still?!
Old Dec 24, 2008 | 09:27 PM
  #57
2004Black350z
Exhaust Whore
Old Dec 24, 2008 | 09:41 PM
  #58
Hydrazine's Avatar
Hydrazine
Look above. There are links of the two systems below the bottom picture.
Old Dec 24, 2008 | 09:57 PM
  #59
OldDirty Z33
rEAding FTW
Old Dec 25, 2008 | 10:19 AM
  #60
turborevdboy11's Avatar
turborevdboy11
Tony that dual set up is gorgeous! I may need to upgrade from my single shockwave set up! Ti tips! Tony know's his ****!
