intake manifold cleanup
Old Dec 28, 2008 | 08:59 PM
tony530's Avatar
tony530
Angry intake manifold cleanup
i just cleanup my intake manifold hella dirty from the pervious owner abuse the **** out of it he had a cold air intake and had it hella dirty filter black dust **** in the filter all the way to the trottle body do i clean it up today!!! so i clean up intake manifold upperand reuse my upper manifold gasket and throttle body gasket and it giving me a headace!!!!! the engine sersive soon light ever sincei opened it up ??? is it cuz i have a leak for someting?? i reseted my ecu reset!! sorry for the headace??
Old Dec 28, 2008 | 09:05 PM
Konvict's Avatar
Konvict
i got a headache from reading
Old Dec 28, 2008 | 09:53 PM
350ZTheStandard's Avatar
350ZTheStandard
IS your BRAne hurting you???
Old Dec 28, 2008 | 09:56 PM
Italianjoe1's Avatar
Italianjoe1
Must... get... spellcheck...
Did you put all the gaskets back in correctly? Did you leave a sensor unplugged or something?
Old Dec 28, 2008 | 10:02 PM
tony530's Avatar
tony530
Angry
i checked all my hoses back and senors back and it still givin me a engine soon serivce light sorry for the spellin check i been drinkin alittle cuz of the
problem???
Old Dec 28, 2008 | 10:32 PM
Sablelieger's Avatar
Sablelieger
problem???
That's why you should never drink and type...
Old Dec 28, 2008 | 10:34 PM
tony530's Avatar
tony530
i know it just buggin me for a while!!!cant figure it out
Old Dec 28, 2008 | 10:39 PM
calin's Avatar
calin
well said Mr. Kimmerz, well said
Old Dec 28, 2008 | 11:01 PM
BERTO's Avatar
BERTO
whoa. I had to read it 3 time to make sense of it all.
Dude, check of of your connections, vacuum lines, and make sure your gaskets are aligned.
While the engine is running, spray carb cleaner around the intake manifold and if the idle rises, you know you have a leak. Be sure the engine is not too hot when you do this. also, did you check the MAF to make sure it was also clean/positioned correctly/hooked up?
Old Dec 28, 2008 | 11:44 PM
tony530's Avatar
tony530
YEA i been doing that with the carb cleaner!!!! i finish the spray today and didnt see the problem with the spray didnt rinse or anything...but when i start it up it make a wired noise idle high about 15000rpm in the began then claim down to normal to 1000rpm...but when i rev it up and let go of the gas it holds up there kinda for a sec or tow after lettiing go of the gas pedal if it makes since??i think its a leak with the upper intake manifold throttle body gasket???
Old Dec 28, 2008 | 11:52 PM
calin's Avatar
calin
15k????
how does something claim down?
since what?
geeez dude, check y0 spelling/grammar!.....
Old Dec 29, 2008 | 12:14 AM
tony530's Avatar
tony530
sorry for the grammer still drinking!!!!but when i started it up from a cold start or any start it idle high(a wired loud growl in the start) and claim down to normal..i push on the gas pedal then let go of the pedal.... just to rev it up a little!!!! the rev up kinda hold for a bit??
Old Dec 29, 2008 | 12:18 AM
calin's Avatar
calin
I still don't understand what you're claiming...
Old Dec 29, 2008 | 12:29 AM
tony530's Avatar
tony530
i dont know how to explain it!!! car giving me hella problems about to throw i over the house!!!!lol this sh it different then a honda sh it!!!
Old Dec 29, 2008 | 12:34 AM
liven Z life's Avatar
liven Z life
hella cool man! the only thing better than a honda is gramer.
Old Dec 29, 2008 | 12:36 AM
tony530's Avatar
tony530
nevermind i shoud drive it into the river fuc this nissan shlt better to go back to honda!!!
Old Dec 29, 2008 | 12:46 AM
tony530's Avatar
tony530
ya grammer is better but the z is hard to explain weird *** **** happened to the fucing car i fix one thing and another thing goes badi everybody see me about the kick the sht out of it!! maybe that the trixs!!! kick the sht out of it!!!
Old Dec 29, 2008 | 04:28 AM
English. Its not just for grownups.
Old Dec 29, 2008 | 05:02 AM
0jiggy0's Avatar
0jiggy0
So you got involved in a project on the car too advanced for your skill level. Put the car back improperly, now it runs like ****. You get drunk and still cant fix the problems and that makes hondas better then nissan? Wow they really must be amazing if they auto fix your retardation. *Off to the dealer to buy a honda*
Old Dec 29, 2008 | 06:13 AM
niceguyyy01's Avatar
niceguyyy01
Dude, seriously on the grammar.
Now on to the problem: it sounds definitely like a vacuum leak. If all hoses are good (check for cracks and cuts in old hoses), all plugs are plugged in, mass air is not damaged (you didn't try to clean it did you?)... then it must be a leaking gasket. I will tell you a secret trick for the old gaskets; go get a can of copper spray. Spray both sides of the gasket, let it sit up for 10-15mins getting tacky, then reinstall.
Remember, do all the easy and free stuff first.
