MLS Gaskets?
Old Jan 13, 2009 | 10:36 AM
Hoooper's Avatar
Hoooper
Default MLS Gaskets?
Where do you guys buy replacement multi-layered-steel gaskets for your exhaust? most catbacks seem to come with totally worthless gaskets and i want to replace them with some stock style steel gaskets but i cant seem to find any that arent OEM diameter
Old Jan 13, 2009 | 12:03 PM
HondaKiller's Avatar
HondaKiller
something wrong wtih the OEM diameter? those should work or you can cut your own if you have the machinary.
Dealership has them, they are expensive though. You shouldn't have to replace them, you can reuse as long as they dont look like you grilled them on the grill for an hour.
Old Jan 13, 2009 | 02:00 PM
Hoooper's Avatar
Hoooper
they (OEM) are an undersize diameter for an aftermarket exhaust. they will bolt up but the passage is still undersize
Old Jan 14, 2009 | 12:52 AM
Hoooper's Avatar
Hoooper
anybody?
Old Jan 14, 2009 | 05:42 AM
kramykram's Avatar
kramykram
just order some new ones. i hit up berk or veraciousmotorsports.com when i need replacement gaskets. also napa sells a nice 2.5 gasket that is metal covered with a gasket. to take it 3" you just cut the inside out a little bit. works great.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Nicky R
Sep 20, 2015 01:05 PM
