Stuck! Please help! (Turbo XS Exhaust)
Old Jan 28, 2009 | 09:38 AM
homErx55's Avatar
homErx55
Originally Posted by gsingh350Z
talk about bad quality..
you get what you pay for..
singh; it seems like in all your posts, you never fail to be a moron/loser/douche
Old Jan 28, 2009 | 11:15 AM
halcyon901's Avatar
halcyon901
^+1
he's just a nismo *****...
only time my turboxs drones is in 6th gear b/w 2000-3500rpm or going uphill in low rpw (2nd or 3rd), but i think thats pretty normal for every aftermarket exhaust
Old Jan 28, 2009 | 01:00 PM
smokedout08's Avatar
smokedout08
he does have a negative outlook, doesnt he. I guess to each their own!
Old Jan 28, 2009 | 03:48 PM
singh's Avatar
singh
_______________
didn't mean to hurt your feelings..just saying you get what you pay for..
Old Jan 28, 2009 | 06:10 PM
smokedout08
I completely agree with you now, I just recieved the exhaust earlier today and the finish is not great, needs better welding techniques. On the upside I bought the exhaust for cheap in comparison to others and will still get the same HP......slim to none. I still think that turboxs is a great company that makes quality products when considering the price.
Old Jan 30, 2009 | 05:36 AM
Sixth_Vang's Avatar
Sixth_Vang
Update:
Guys i'm getting some components in today and if I can get them before I go to work I will report back on if it helped with the exhaust drone or not.
Old Jan 30, 2009 | 05:49 AM
Ziggyrama's Avatar
Ziggyrama
Make sure to tighten the bolts to spec. Also, the order in which you connect the pieces matters. Flanges that have 2 bolts will have a higher chances at leaking than the flanges with 3. I always found that doing the 2 bolt connections first helps to minimize the leaks. If you're getting ridiculous drone, you probably have a leak. If you overtighten the gaskets, you will probably have a leak. Usually 30-35 lb. ft. of torque is the right spec. I may attempt to put mine on this Sunday.
Old Jan 30, 2009 | 10:28 AM
Sixth_Vang's Avatar
Sixth_Vang
Failed. I was going to do an magnaflow resonator but it was too large. Owner of the shop said do 2 glasspacks on the y-pipe, i just said f' it if i don't like the drone on my lazy days then the silencers are going in.
I did however get a hangar welded, keeps hitting my subframe. And yes i tried to reinstall it about twice, once by me and the second time by Import Experts. If anyone has this exhaust they'd understand after looking at it.
Old Jan 31, 2009 | 07:37 PM
ntwillie1's Avatar
ntwillie1
I have this exhaust and have no issues with it. I love the way it sounds - at idle and when I step on it. The drone is/was noticeable for me when I cruised in 6th but since getting my HFCs installed I no longer hear/notice the drone whatsoever. I will say it is loud but that was to be expected after adding the HFCs. I'll say the look and quality of the product is not bad. I have no complaints.
I did get the rubbing sound after adding the HFCs but prior to that i had no rubbing/knocking of the exhaust to the car. I took it to my local midas and the guys there put on a shorter hanger on the mid pipe and its perfect again. The fix cost me $15 which was the $15 I tipped the guys - they didn't charge me for the hanger or 20 min of labor.
Old Jan 31, 2009 | 11:56 PM
homErx55's Avatar
homErx55
i love the drone of my txs...
im running stock cats atm.. i cant wait till i get the berk HFC
despite our hanger problem, TXS is so worth the money that was saved..
i think we should end this thread at that.
Old Feb 1, 2009 | 04:27 AM
BlackTuner's Avatar
BlackTuner
Shoot a picture of the rear muffler assembly and email it to me please.\
Thanks,
Jermaine@turboxs.com
Old Feb 2, 2009 | 01:54 AM
Ziggyrama's Avatar
Ziggyrama
I have my TXS waiting to be installed in my basement. I was hoping to get to it yesterday but I didn't. The hanger issue, is it something that all TXS exhaust have or is it that once you put the HFCs, the angles changes slightly and moved the mid pipe so that it started to make contact with the other part? I'm on stock CATs, BTW.
Old Feb 2, 2009 | 06:50 PM
ntwillie1's Avatar
ntwillie1
For me it was never an issue until I installed the HFCs. And after that, installing a smaller hanger for the midpipe fixed the issue.
Old Feb 4, 2009 | 08:03 PM
THe Emperor's Avatar
THe Emperor
Can some of you guys post pictures of your turboxs installed?
Old Feb 5, 2009 | 01:32 PM
ntwillie1's Avatar
ntwillie1
here's mine, i can take a better pic this weekend if you like as its supposed to be like summer here ( 50 degrees ;0 ). Let me know if you want underbody shots or what angle you like. And before anyone mentions it - its already been lowered. these were taken before i lowered it.
Attached Thumbnails Stuck! Please help! (Turbo XS Exhaust)-dsc_0063vx.jpg   Stuck! Please help! (Turbo XS Exhaust)-dsc_0069vx.jpg
Old Feb 5, 2009 | 07:43 PM
THe Emperor
Thanks, thats looks great!
Old Feb 6, 2009 | 01:34 AM
Ziggyrama's Avatar
Ziggyrama
I'll try to install mine tomorrow and take pics. The weather is supposed to cooperate so hopefully I'll get it done.
Old Feb 6, 2009 | 09:45 AM
  #38
THe Emperor
ntwillie1, yes underbody and angle shots would be great too. Thanks.
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
