Test Pipe Gains?
Old Sep 13, 2003 | 10:58 AM
shil01's Avatar
shil01
Toykilla please please post a sound clip!
Old Sep 13, 2003 | 05:17 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Yeah i'd love a sound clip... webcarconnection, you've been a pioneer at posting sound clips before
We'd love to hear your headers/testpipes/borla combo.
Old Sep 14, 2003 | 01:39 PM
shil01's Avatar
shil01
So is FI the only reason to go 2.5' instead of the 2.25'? I want to put these on a stock exhaust setup (which i think is 2.25') so wouldnt 2.25' be best? I do plan on going with a Borla setup later and maybe FI down the road so maybe 2.5 would be a better choice? Basically my question is if I get 2.5' pipes and my stock setup is 2.25 isnt that going to mess up the air flow???
And PLEASE PLEASE someone post a sound clip of these damn pipes with a stock setup!
To all vendors selling these pipes: I think that exhaust note ranks right up there with HP gains, so advertising with a sound clip of what these will sound like would be most benificial for you guys! IM NOT BUYING CUZ I DONT KNOW WHAT IT SOUNDS LIKE!
please help..thanks.
Old Sep 14, 2003 | 01:43 PM
MY350Z.COM's Avatar
If you are FI I would recommend 2.75" - 3.00"
2.25" is best for stock system and Borla and any other system that uses 2.25"
use 2.5" if you are using a Stillen exhaust sytem or other systems that utilize 2.5" piping.
using 2.5" with the stock system shouldn't dusrupt the airflow too much, you will see gains but it would be better if you went with 2.25"
Old Sep 14, 2003 | 01:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
honestly, 2.5 is plenty for FI on these cars - will easily flow 400 + HP worth of air,a nd at least it won't require you to make it custom, or run into possible rubbing issues
Old Sep 14, 2003 | 03:44 PM
92hatchattack's Avatar
92hatchattack
i think even 2.25 might work well enough for fi ....... i will be going 2.25 all the way back for now ....being that i will be NA for quite some time........ but yeah ... i would think 2.5 would be ideal for a TT setup.... and i surely donth think i go bigger that 2.75... unless pussing insaine hp #'s
Old Sep 14, 2003 | 04:47 PM
rodH's Avatar
rodH
THATS WHY I AM WAITING TOO
Old Sep 14, 2003 | 07:43 PM
webcarconnection's Avatar
webcarconnection
The thing of the sound "raspy, metal, what ever you want to call it" was that if you have Borla TD w Cats Pipes that kind of sound ("leaking") is gonna be more noticible w the cats pipes because you have more exhaust running through your system. the Borla exhaust is the best for HP (my opinion) but have very weak form of bind... if you have NO leaks on your Borla and have the Cats Pipes you have a very noticeble tone of exhaust!( in the Best way)
Ok... My Brother have the Cats pipes w Injen and I have it w Borla and Borla Headers, I'm gonna talk to him to record it both... give me a couple of days to see what I can do!
Old Sep 14, 2003 | 08:46 PM
MY350Z.COM's Avatar
do you know where these leaks come from?
Old Sep 14, 2003 | 09:21 PM
92hatchattack
correct me if in wrong, but arent both the Bolra header collector ID and the true dual ID(internal diameter) 2.25, not 2.5????
and yes, as far as these "leaks" from the bolra exaust go, where are they comming from, and what can be done to stop them????
Old Sep 14, 2003 | 10:44 PM
KONVERTER's Avatar
KONVERTER
I have MINES test pipes on the way i got from a group buy on here for 350... i forget the diamter of the pipe... i havent been on a computer for like 3 weeks so i have forgotten everything.. i have it book marked on my computer at home.. ill be home on teh 20th.. and then back out of town on the 25th tilll the 1st.. grrrrrrrr... i miss my z!!!
Old Sep 15, 2003 | 06:06 AM
99AllTurbo's Avatar
99AllTurbo
Webcar, can these be videos please and not sound clips. The videos sound much better.
I have the Injen so I hope I can hear your brother's Z.
Thanks in advanced guys.
Old Sep 15, 2003 | 06:45 AM
carlosG's Avatar
carlosG
To clarify on the issue of leak in borlas exhaust
You should check on the clamps both on the H pipe, resonator and muffler, the reason being is that these clamps with the expantion and contraction of the staineless steel due to the heat they tend to loosen up. I had to weld my exhaust in 6 places front of the H pipe which in fact has been eliminated back of H pipe and front of the silencers. my exhaust now sounds great. I have the cat pipes and plenum from crawford and my engine sounds amazing. with regards to my post you can corroborate w webcar.
Old Sep 15, 2003 | 07:37 AM
webcarconnection
My friend CarlosG is correct... thanks for clarify
the sounds clips are gonna be on video don't worry
Old Sep 16, 2003 | 05:56 PM
ROLANDO SANCHEZ's Avatar
ROLANDO SANCHEZ
i have a stillen supercharger with stillen exhaust and have the same test pipes as zred.. the test pipes do make the car sound like a honda...i am going to put back my cats... the sound before was a nice deep sound.. also i believe after i removed my cats the car seems like it lost hp.. i believe due to my experience with z cars they do need back pressure for better performance.....
Old Sep 16, 2003 | 06:05 PM
webcarconnection
Hmm do you dyno or track your car to proof this theory... you have FI engine you need less back pressure than the N/A...
Old Sep 16, 2003 | 07:17 PM
ponykiller's Avatar
ponykiller
Some people in here have a few misconceptions about turbochargers exhaust sizing. BIGGER IS BETTER! If you can true dual 3" pipes, then do it! You want absolutely no back pressure with turbocharged applications (unlike naturally aspirated engines), as the turbos will spool faster. This means less lag and full boost at a lower rpm, and max power is also going to be increased.
Old Sep 30, 2003 | 12:41 PM
  #38
VQ35DES's Avatar
VQ35DES
wow, nice sound clips...
Old Sep 30, 2003 | 01:18 PM
  #39
g356gear's Avatar
g356gear
5 hp and 10 ft lbs across the board
Old Oct 17, 2003 | 10:07 PM
  #40
Import-Tooner's Avatar
Import-Tooner
I've yet to see/hear them.
I'm kinda new and wondered, what size test pipe should I use if I get the injen dual exhaust? Or, what size is the piping on the injen?
