strut bar issue with 5/16" plenum spacer
Old Mar 20, 2009 | 05:46 PM
richiesaurusrex's Avatar
richiesaurusrex
Default strut bar issue with 5/16" plenum spacer
so i put my motordyne 5/16" plenum spacer on last night no problem, but when i was putting the strut bar back on it was resting right on the plenum. So i'm rolling with no strut bar for now, so what are my options??? The kit didn't come with strut bar spacers, and I thought the 5/16" plenum spacer didnt need strut bar spacers, but i could be wrong. Does the strut bar really make a difference??? And where can I get the spacers from and what size??? Also what mod next, i have a popcharger, plenum spacer, hks exhaust...
Old Mar 20, 2009 | 05:59 PM
omniskillz's Avatar
omniskillz
Im going to guess getting your ECU flashed/Tuned, changing your suspension and new wheels?
as for the plenum, try this
http://www.motordyneengineering.com/manual.pdf
look at page 8 of 9 for Strut Bar Reinstallation and Adjustment for 350Z:
Old Mar 20, 2009 | 06:19 PM
WhiskeyHotel's Avatar
WhiskeyHotel
I believe it should have come with strut bar spacers - they're in the parts list....
Old Mar 20, 2009 | 06:46 PM
UnFairLady Z's Avatar
UnFairLady Z
i left my strut off after install no biggie to me i dont track the car n e way
Old Mar 20, 2009 | 07:26 PM
Surprised. I have the Motordyne 5/16 Plenum Spacer. It came with spacers.
Old Mar 20, 2009 | 10:52 PM
polish pete's Avatar
polish pete
get a bunch of the same size washers, and stack them under the bar.
Old Mar 21, 2009 | 06:11 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Yes, when you use the spacer on the Z, you must also use the strut bar spacers if you want the strut bar to fit.
Did you order the 350Z or G35 kit?
Old Mar 21, 2009 | 11:49 AM
69 fingers's Avatar
69 fingers
Just call the supplier, tell them you didn't get the spacers, and have them ship them to you....overnight.
I ordered the same Motordyne plenum spacer, and it definitely comes with spacers.
Old Mar 21, 2009 | 11:56 AM
350z-Jim's Avatar
350z-Jim
Just go to home depot and pick up some washers and prop it up, no big deal. Mine has 3 washers under to give me the room. You can't see them unless you lay down really low and look.
Old Mar 22, 2009 | 03:48 PM
richiesaurusrex
thanks you guys, yea i emailed them friday night and hopefully they get back to me monday. I definitely ordered the 350z kit, so yea...
Old Mar 22, 2009 | 03:50 PM
richiesaurusrex
the only reson i care is that i would have gotten the 1/2in spacer if i were gonna leave the strut bar off.
Old Mar 22, 2009 | 04:02 PM
Hydrazine's Avatar
Hydrazine
Strut bar spacers are on the way!
PM'ed.
Old Mar 22, 2009 | 06:52 PM
richiesaurusrex
Motordyne is on the ball, thanks a lot!!!
And is it a perfect fit, or is their an issue with the hood hitting the strut bar, or how does this work? What have you guys found?
Old Apr 2, 2009 | 06:25 PM
phreaktor's Avatar
phreaktor
Design Engineer
Search noob.
Old Apr 3, 2009 | 06:27 AM
VO...'s Avatar
VO...
Administrator
I'm really suprised you need the communities help, being such a young knowledgable man and all...
https://my350z.com/forum/the-lounge-...fe-crisis.html
https://my350z.com/forum/the-lounge-...first-car.html
Old May 27, 2009 | 04:32 PM
nosurf2day's Avatar
nosurf2day
What are the size/dimension of the bolts and the nut that go to the strut bar? They are not metric from what I can tell. They seem to be standard, I went to ace and i forgot to write it down. I want to order chrome bolts online and this is the only bolts I have left to put in the cart. I am having a hard time trying to figure this out.
Old May 27, 2009 | 05:50 PM
Hydrazine's Avatar
Hydrazine
The ones that come with the spacer kit are Metric M10 bolts 30mm long @ 1.25 thread pitch.
Old May 27, 2009 | 07:40 PM
finalforce's Avatar
finalforce
I used washers and my hood slightly rubs the strut bar, but no big deal for me. I don't DD my Z.
Old May 27, 2009 | 07:42 PM
03aeroZ's Avatar
03aeroZ
^Take the little rubber stops off of the hood...you shouldn't have any more problems.
Old May 29, 2009 | 12:54 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
use 16 3/8 washers...2 for each of the 6 bolts and 2 for each of the small nuts...that will clear you without rubbing the plenum or the hood. im running the exact setup as you but with the ARC strut bar. next time search more...vo7848 did a DIY spacer install, thats how i found out what to use.
