MD plenum SPacer + 06 Airbox Dyno
Old Mar 29, 2009 | 07:35 AM
SuperMiguel's Avatar
SuperMiguel
Default MD plenum SPacer + 06 Airbox Dyno
Well i went yest and got a dyno on my z. Mods: MD plenum SPacer + 06 Airbox Dyno
1st run : 244.71 max power 227.31 torque
2nd rub: 251.69 max power 237.08 torque
3rd run 248.81 max power 239.55 torque
Will try to get the HFC next week and update dyno numbers
Old Mar 29, 2009 | 08:07 AM
03threefiftyz's Avatar
03threefiftyz
Is the 1st run your basline? If so nice gains for a couple hundred bucks. Especailly in torque.
Old Mar 29, 2009 | 10:00 AM
SuperMiguel
yep 1st dyno
Old Apr 5, 2009 | 06:07 PM
350ZnFuture's Avatar
350ZnFuture
nice just ordered my spacer, is yours the 5/16th?
Old Apr 5, 2009 | 07:12 PM
Voboy's Avatar
Voboy
5AT?
edit: oops i searched and found out you have a non-revup z.
Old Apr 5, 2009 | 10:56 PM
SniperHunter's Avatar
SniperHunter
Great gains. Last week I took the hour* out of my day and popped my OEM 06 airbox back in, and it truly is the best damn intake you can have for your DE Z.
*1 Hour turned into more than that when I dropped the screwdriver, and had to remove the undercarriage panels.
Old Apr 6, 2009 | 03:23 AM
SuperMiguel
yep
agreed i had the pop charger but i like the airbox alot alot more.
Old Apr 6, 2009 | 08:23 AM
350ZnFuture
y do you think your third run was low on hp?
Old Apr 6, 2009 | 01:11 PM
Jeff92se's Avatar
Jeff92se
Arnold. My crawford V5, X piped borla and RU airbox mod are really kicking butt. You felt a big diff went put the oem box back in?
Old Apr 7, 2009 | 12:00 PM
ajcool2's Avatar
ajcool2
What kind of dyno was this?
Old Apr 7, 2009 | 12:39 PM
03threefiftyz
looks like a dynojet to me.
Old Apr 7, 2009 | 12:50 PM
ajcool2's Avatar
ajcool2
Looks pretty good then. If I could find an 06 airbox I'd probably switch over.
Old Apr 7, 2009 | 02:26 PM
SchismX's Avatar
SchismX
What is the difference between an 03-05 airbox and the 06? Internal differences, like baffles, etc.?
Old Apr 7, 2009 | 02:31 PM
Jeff92se's Avatar
Jeff92se
velocity stack height diff. It's small but it does make a difference.
Old Apr 8, 2009 | 04:28 AM
SuperMiguel
i may do pulleys next and dyno again and see if they really give 10rwhp
Old Apr 8, 2009 | 04:35 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
MD + 06 airbox setup FTW! i had that setup on my Z when i was N/A. sweet !
chefj
AbrasiveRaysive
Sep 13, 2015 09:52 PM
