knn recharge NEED HELP QUICK!
Old Apr 4, 2009 | 09:53 PM
quietkilla6's Avatar
quietkilla6
Default knn recharge NEED HELP QUICK!
I just cleaned my knn filter and let it air dry and now im worried about putting the right amount of oil on the filter. i sprayed it and i think i sprayed it to much but the clean side isnt red it sorta pink but the dirty side is red and foamy. i have to go to sleep asap its 11pm in az and i have to wake at 5am so quick help would be great.
thanks guys
Old Apr 4, 2009 | 10:51 PM
s31t8n8's Avatar
s31t8n8
if you think you sprayed too much than just wash it again and start over
Old Apr 4, 2009 | 11:03 PM
Ruthless18x's Avatar
Ruthless18x
Yeah that sound's like way too much. If it's just a little extra, hang it upside down and spin it with your arm. Should even it out.
Old Apr 5, 2009 | 03:13 AM
zdotcom's Avatar
zdotcom
Wrap it in newspaper overnight.
Old Apr 5, 2009 | 06:27 AM
The "More is better" philosophy does not work well when oiling a filter. The possible downside of too much oil is fouling the MAF sensor.
Old Apr 5, 2009 | 09:04 AM
quietkilla6
well you guys were to late.... i had to use it to get to work. But i let it sit over night and it seemed fine. the foam was kinda me exagerating it wasnt foaming terribly. just alittle. im not to worried i just get unsure. im going to check it before i leave work and see if theres any sighn of oil in the intake tube. the problem with washing and reoiling is i had to work at 5 am and it take like 8 hours to dry. and it was 11 so 2 hours to short. im probley going to check my censor also and if theres red oil ill spray it clean. it just sux because i already had to clean my maf and throttle body soon after i bought the filter.
Old Apr 5, 2009 | 11:18 AM
350ZTheStandard's Avatar
350ZTheStandard
I have 2 filters for this exact reason, besides being able to make sure I am not coating my MAF with the oil I can quickly replace the filter and be done with the yob. I usually clean the filtet that just came off the Z and place it in a zip lock 1lb bag till needed.
Old Apr 5, 2009 | 11:55 AM
sry110's Avatar
sry110
I used to swap in my OEM airbox every time I cleaned my popcharger filter, but I think I am going to follow your lead and buy a 2nd filter. Much easier and no worries about running out of time and having to drive with a wet or over-oiled filter.
Old Apr 6, 2009 | 07:49 PM
350ZTheStandard
Took me a while to figure this out, think I will be changing my filter this upcoming weekend.
Old Apr 7, 2009 | 09:09 AM
Jeff92se's Avatar
Jeff92se
Clean at night, let dry overnight. oil filter in morning. let sit for 5 min. Install and enjoy.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
juang20
Intake
Sep 7, 2015 05:37 PM
