Stock air filter vs. K&N
With the SC i could tell a considerable difference in the butt dyno between my OEM and the Amsoil. But i think that's mainly because i'm flowing more air. But between the K&N and Amsoil i could tell no difference.
So IMO i think the Amsoil filter is a SAFE alternative to the Oil filter in a FI setup. And OEM is just fine for a NA motor.
He's pro'bly talking about the Fram Air Hog, which is simply the equivalent of a K&N. The K&N filter was possibly in dire need of a good clean-up, like some of you dudes suggested. I've had a K&N for about a year now, & I ain't got any regrets about purchasing it! A once-a-year recharge kit clean-up does wonders!
you guys are so lame. just use oem filter, any other filter will be less restrictive, it will induce the engine to use unfiltered air, and it will yield little to no horsepower.
the guys using aftermarket and say they feel "an increase in throttle respone" are all full of shiit.
I've used them since they came out. UNTILL someone brought up a good point on here. Next time you clean your filter hold it up to the light before you re-install it. Look at the thousands of pinholes in it! After i did that, i will NEVER put another K&N filter in my car, or any car!!
Well first off, improvements in air intake are not going to help you that much, at least not by themselves. <---NOTICE key phrase...
An engine is essentially an air pump. You can try to bring as much air as you want through the intake, but the engine is only going to take in what it can exhaust. So if the exhaust can't push the amount of air that the intake can pull....guess what? You've just wasted your money.
Secondly, while K&N filters, or many other after market high flow filters for that matter, do allow a larger volume of air to come through into the intake, the problem is that they let more dirt through to accomplish it.
Now, when combined with an after market, less restrictive exhuast system, whether that consists of HFCs, test pipes, etc. and the exhaust then you will not only hear the difference but also feel it on the butt dyno as well as see it on a real dyno.
Personally, I prefer the coned filters from a CAI or short ram rather than the drop ins. It seems that you see less "pin holes" with the coned filters. I swap my Injen CAI filter with a clean one each time I change my oil and I've had no problems with it.
My 2 cents...
This depends on other factors...
My 2 cents...
My 2 cents...
For example.....I've got a Stillen blower, the only FI out there that you can still use the stock intake with. After a couple years i went from my poop charger to a 2006 OEM airbox with a drop in Amosil dry filter for the purpose of gettign more cold air in, vice the "hot air" effects of short ram intakes like the poop charger. I was plesantly surprised to feel a significant improvement in the butt dyno, not to mention lessened heat soak as well. Not saying it necesarly flowed more then the poop charger. But it definatly didn't flow any less.
My point being, if i'm not out flowing the OEM box with a blower spinning 12,000 RPMs. Then i HIGHLY doubt you are going to outflow the OEM filter and box in a NA motor.
Also, don't forget. The intake pipe is only 3 1/2 ID. Whereas the airbox has significanty more surface area. it's not as if you are trying to flow all that air across a 3 1/2 inch area of your filter. Thus the large panel filter Nissan uses which would counter act any restriction of the OEM filter.
Yeah no $hit. Gotta pay to play tho!!
Just remember, when you push the envelope on performance, in turn you sacrafice reliability. K&N is a prime example of that.
