5/16" Motordyne spacers???
Old May 13, 2009 | 04:56 PM
SpeedDemon20's Avatar
SpeedDemon20
Default 5/16" Motordyne spacers???
http://motordyneengineering.com/cata...cPath=24_21_28
I dont know which one to get there is 2 different 5/16 spacers.
Basic Plenum Spacer
Iso Thermal plenum spacer
Help plz
Old May 13, 2009 | 05:02 PM
iamdigital's Avatar
iamdigital
If you drive in cold weather go for the ISO thermal. If not, get the cheaper one...
Old May 13, 2009 | 05:12 PM
SpeedDemon20
I live in Arizona lol, fukin hot!!!
Thx bro
Old May 13, 2009 | 05:38 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The Iso Themal will actually be quite usefull in hot weather.
It will reduce the upper and lower plenum assembly temperature by 30-60 deg F. The air flowing inside the plenum will also be cooler because of it.
Old May 13, 2009 | 10:04 PM
yaro's350z's Avatar
yaro's350z
this may be a late reply but whatever..
i just installed my MD 5/16 spacer.
install went smooth, but i noticed it is running low rpm's, almost to the point of shutting off..(500-600)
i'm thinking its some loose bolts.
but also, i didn't remove the stock gasket, its really thin and the manual says it's not necessary to remove it.
can this have anything to do wit the low rpm's.
thanks.
Old May 14, 2009 | 01:08 AM
SpeedDemon20
so get an iso thermal for sure???
Old May 14, 2009 | 02:36 AM
halfass872's Avatar
halfass872
thanks.
WOW!! Way to threadjack!!
Old May 14, 2009 | 05:14 AM
Hydrazine's Avatar
Hydrazine
thanks.
Check for leaks, check to make sure all the hoses are plugged back in. Check to make sure the rubber oil spout filling ring is not suck between the plenum sealing surfaces.
If its not any of those, the throttle body may need a rest. The reset procedure is listed on the back of the installation manual.
Old May 14, 2009 | 07:37 AM
Thermal1's Avatar
Thermal1
Yes. Good choice
Old May 14, 2009 | 08:01 AM
yaro's350z's Avatar
yaro's350z
i didn't mean to, just thought i'd ask a simple question instead of starting another thread about it..
thanks for your help, ill make sure to check all these things.
Old May 14, 2009 | 08:29 AM
halfass872's Avatar
halfass872
There's a textbook definition of Thread Jacking!! lol
Old May 14, 2009 | 11:50 AM
yaro's350z's Avatar
yaro's350z
well now that i have my answer im all set.
ill let you guys get back to the important discussion ya'll were havin..
Old May 14, 2009 | 04:51 PM
SpeedDemon20
k thx guys, looks like ill go with the iso thermal! Don eva jack mah thread! jk
_koubie_
Sep 20, 2015 06:34 PM
