08 nismo header on an 05z????need help
Hi guys
I would like to know if the oem nismo headers are the same as the aftermarket nismo headers at 1200$? Is it possible to install the 08 nismo header on a 05 z??? Will it bolt on....
thanks
thanks
Since there is no performance difference between a 2007/2008 Z and a Nismo edition Z, the aftermarket Nismo header is going to be the better of the two. But A 2007-2008 Z and Nismo Z has the HR motor, you have a DE motor. So i'd imagine any header for the HR motor would be "tuned" differently the it would be if it was made to use on your your motor. So you'd need the Nismo headers ment for a 2003-2005 non rev-up Z.
Remember the Nismo edition Z is just a normal Z with handling and cosmetic upgrades. The engine and drivetrain in it are exactly the same as a 2007/2008 Z.
