plenum spacer help
Old Sep 4, 2009 | 12:41 PM
gmic350z's Avatar
gmic350z
Default plenum spacer help
so ive got an 03 z and i put the spacer in about 4 months ago,i noticed the car was running kinda louder than normal and was hesitating off the line so i find out the spacer was leaking,i tightened down bolts and worked fine for a week and then it leaked again.so i took it apart and added some intake sealant all around.worked good for a few days and its leaking again.so how can i take care of this,once and for all..also i went and got dyno the day i sealed it and came back with 240 hp and real low tourqe numbers..is that normal for an 03 auto..by the way its the motordyne spacer...any help?
Old Sep 4, 2009 | 01:01 PM
Globalscan's Avatar
Globalscan
did you soak the gasket in oil first?
Old Sep 4, 2009 | 01:30 PM
gmic350z's Avatar
gmic350z
the smaller gasket yes, but the bigger gasket that seals the plenum,no..didnt see that in the instructions,it says only the smaller..?
Old Sep 4, 2009 | 01:42 PM
gmic350z's Avatar
gmic350z
sorry just noticed im in the 370 section..
Old Sep 7, 2009 | 02:06 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
It may not be the spacer leaking at all. It sounds like you may need a throttle body reset procedure.
Its listed on the last page of the installation manual.
Try it and let me know what you find.
Tony
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
