Old Dec 22, 2009 | 09:13 PM
asianmania's Avatar
asianmania
Default Exhaust
don't think this Q is on here.
just took a look at my exhaust and my right exhaust outlet does not stick out as far as my right exhaust outlet. the right is about 2 in shy of the other. dont know if it hit it driving in my parking garage at my apartment. any help is appreciated
Old Dec 22, 2009 | 09:36 PM
s31t8n8's Avatar
s31t8n8
stock exhaust? aftermarket exhaust? take a look at the hanger for the side that is not sticking out far enough (you said right twice)
Old Dec 22, 2009 | 09:46 PM
Waiz's Avatar
Waiz
Wrong forum noob.
This had nothing to do with a Roadster and should be in the exhaust subforum.
Old Dec 23, 2009 | 02:57 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
The right doesn't stick out as far as the right???????? I think you LEFT something out.
Old Dec 23, 2009 | 03:32 AM
Phreakdout's Avatar
Phreakdout
You probably backed into something or someone hit your car in a parking lot.
1st: Check if it's loose or bent. Crawl under and check to see if the hanger rods on the muffler are pushed all the way into the hanger bushings. (The rubber mounts that attach to the underside of the car.) Push the rod back in if it was pushed out.
2nd: If the rods are all ok, check the 2 bolt flange between the midpipe and the muffler assembly. Loosen it up and try adjusting the exhaust. Can you get it back in position? If so, then tighten. Did it draw back out of position? If so, you flange is probably bent. A muffler shop can heat and beat it into place. Otherwise, it's a good time to consider aftermarket exhaust!
3rd, if that flange is straight, check the flanges going forward. If you bottomed out on the Y-pipe, it can pull on the exhaust. Nissan uses all flat flanges so there's not much adjustment in the system. (Versus ball flanges like what Toyota uses. You can get 5 degrees out of those systems before leaking.)
Old Dec 24, 2009 | 07:09 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Dec 24, 2009 | 07:10 AM
VO...'s Avatar
VO...
Administrator
To answer your question, yes the stock exhaust was actually built like that. One side always pertrudes out further than the other. I do not know why that is, but it is...
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
Li1ag
Sep 28, 2015 02:07 PM
