Tanabe Medallion + Berk HFC
Old Feb 11, 2010 | 05:38 AM
rich2342's Avatar
rich2342
Alright,
The Berk HFC is 60mm(pretty sure) the Y-pipe would be 70mm along with the remainder of Mid-pipe and exhuast.
Is there going to be any issues?
Old Feb 11, 2010 | 05:55 AM
AZHR's Avatar
AZHR
Originally Posted by rich2342
Alright,
nope, no issues.
Old Feb 11, 2010 | 02:33 PM
terrasmak's Avatar
Well i didn't run HFC's on mine i ran resonated test pipes. Sounded great, still quiet, not raspy and completely different than a Nismo with test pipes.
Old Feb 11, 2010 | 03:37 PM
brandon3434's Avatar
brandon3434
Originally Posted by tylerxfire
im not positive but pretty sure they are the same design and the tanabe is a knockoff of the nismo design...looks like the tanabe is the same design to me but idk..ive heard of people using the tanabe mid pipe and all on a nismo cat back
http://cgi.ebay.com/ebaymotors/TANAB...Q5fAccessories
^look at the design
http://ep.yimg.com/ca/I/phase2motors...2091_257238120
This is wrong, the tanabe midpipe does NOT work with a nismo...I was thinking about doing this a few months ago...I just bought a complete nismo instead...Good luck!
Old Feb 11, 2010 | 04:15 PM
rich2342's Avatar
rich2342
I don't understand the comparison either and I wasn't making one in the o.p.
Im asking if anyone has done it or if there will be issues with berk cats(60mm) into 70mm piping of tanabe exhuast and mid-pipe.
Old Feb 12, 2010 | 07:57 AM
Highway Riding's Avatar
Highway Riding
call Berk or Z1auto (NY) and ask them the diameter of the Berks. I thought they were 2.5 as opposed to the 2.36 diameter of the Tanabe Y pipe. The Tanabe mid pipe is 70mm
so essentially you want a 60 mm HFC to use with the T y pipe. If Berk is in fact 60 mm (2.36) then you will have zero issue with flow. If they (Berk HFC's) are 2.5 i'm not sure what to expect since the stock headers are closer to 2.36 if not 2.36
essentially a good Tanabe setup would be as follows!
HFC's or test pipes of ur choice 60mm - Tanabe Y pipe = 60mm merges to 70 mm -Tanabe mid pipe = 70 mm - exhaust inlet = 70 mm
Old Feb 12, 2010 | 10:23 AM
rich2342's Avatar
rich2342
Which Y-pipe did you go with Tanabe or Another?
do you have any clips?
I want to avoid the rasp for a clean awesome exhaust like the Tanabe.
Old Feb 12, 2010 | 03:20 PM
terrasmak's Avatar
Tanabe Y pipe, and for the price buy the motordyne XYZ its a much better product.
Sound clips, never have and never will post them. They never sound the same as in person.
Old Feb 12, 2010 | 04:26 PM
tylerxfire's Avatar
tylerxfire
dude ur thinking too much into it...just get the berk high flow cats if u want high flows and put them on, u wont have rasp with that setup, and if by some slight chance u do get rasp or want it deeper and cleaner get the motordyne xyz w/ resonator..the motordyne xyz is the best y pipe money can buy and worth every penny, i love mine, i dont rasp with berk test pipes with my xyz w/ resonator and nismo mid and tail section but had rasp with my normal nismo y pipe
Old Feb 16, 2010 | 08:25 AM
rich2342's Avatar
rich2342
Well,
Just dropped 1400+ bucks on this plus HFC's and Spacer, so we'll see how it sounds without the Y-pipe for now.
Anyone install HFC's and exhaust themselves? Can I do it with Just a floor jack and two ramps or no?
Old Feb 16, 2010 | 11:07 AM
Highway Riding
Well,
Nice. If possible please measure or let us know if they are in fact 60mm. I have been getting ready to order a set of Tomei test pipes because they are 60mm but if the HFC's are 60mm i'll grab those instead.. No rush for me since the Z is under 2 ft. of snow
Old Feb 16, 2010 | 11:51 AM
rich2342's Avatar
rich2342
Almost positive it is 60mm but I'll measure, and be a Guinea pig for this set-up.
Can't believe noone on here has this configuration..?
Old Feb 16, 2010 | 03:18 PM
tylerxfire's Avatar
tylerxfire
floor jack is fine..ramps prolly are too but i cant get on ramps..hard enough getting a jack under my car..be ready to get bruised up knuckles swapping the cats, have extensions and bars to put on the end of the socket for extra leverage handy
Old Feb 20, 2010 | 05:02 PM
TheBlue350z's Avatar
TheBlue350z
I got a question about the pipping size of the berk HFC... i have AAM y-pipe and it is 2.5" and goes to 3"... The berk HFC are 2.36". Would there be any problems with this setup?
Old Feb 23, 2010 | 08:07 PM
350zDex's Avatar
350zDex
i use to have this tanabe exhaust and man did it sound great, i had kinetix hfc's and a motordyne y-pipe. The sound of it was amazing and made great power, never got to get a sound clip of it , maybe i could get one from my friend cause i sold it to him.
Old Feb 24, 2010 | 05:03 AM
rich2342's Avatar
rich2342
Yeah if you could do that I'd appreciate it. Did you experience any hiss from the hfc's with your set up that you recall?
For now im Im going to use the stock Y-pipe until i can find a used aftermarket or HR Y-pipe.
Im sure the hfc's increased the decibal level a bit huh?
How was the drone?
Old Feb 24, 2010 | 01:46 PM
na_350z's Avatar
na_350z
While I don't have the Touring edition I have the Tanabe Hyper Medallion. I have it matched up with the Tanabe Y-Pipe and the Berk HFC's. The HFC's matched up just fine to the Stock & Tanabe Y-Pipe. The HFC's do provide some hiss and they also produce very little rasp when WOT. The exhaust note is loud enough to phase out the rasp. Overall its an amazing sounding exhaust.
Old Feb 24, 2010 | 05:48 PM
  #38
rich2342's Avatar
rich2342
Do you have any youtube vids?
Did the car have any studder after the hfc install?
Old Feb 28, 2010 | 06:59 PM
  #39
350zDex's Avatar
350zDex
yeah if you could do that i'd appreciate it. Did you experience any hiss from the hfc's with your set up that you recall?
For now im im going to use the stock y-pipe until i can find a used aftermarket or hr y-pipe.
How was the drone?
no hiss, that i recall and no drone at all, its a quite amazing sounding exhaust!!
Old Mar 8, 2010 | 08:35 AM
  #40
rich2342's Avatar
rich2342
Ha ha ha..
So I went to go attempt to put this on with only two ramps.
Taking the oem rear section off with no room is a *****. I get that off and I hadn't looked at the midpipe to compare. The oem did not mate up with the Tanabe...argh.
I was putting it on temporarily because my buddy(with proper tools bailed).
After spending about 2 hours wrestling with the rubber hangers removing the oem, I had to put it back since I didnt have clearance to reach mid-pipe.
I had to laugh..
