Installed my md copper 5/16 spacer...
Old Mar 10, 2010 | 05:44 AM
rich2342's Avatar
rich2342
Default Installed my md copper 5/16 spacer...
Did this yesterday. Car was stock prior.
I added the Tanabee exhaust and Plenum spacer along with a basterdized AEM cai which i reduced to a sri.
First off, The car idles nicely after install and it was done according to instructions.
The added torque is noticeable down low up until 5k-6k where she seemed to run out of breath.
The added pull was nice down low but almost at 5k and beyond was no longer linear.
Shouldn't the opposite occur cruising at highway speeds or should I give the Ecu time to adjust some more?
Old Mar 10, 2010 | 06:37 AM
Unique_Z33's Avatar
Unique_Z33
I know there is controversy about this but... After my exhaust and 5/16 spacer I disconnected the neg off the battery overnight to "reset" the ECU. That way it adjusts properly to the new mods. My butt dyno said, win! But like I said there is controversey if it really works or not. Also to get the the most out of any mod(s). I reccomend a tune. Of course this should be done lastly, so you dont waste your monies!
Old Mar 10, 2010 | 06:40 AM
rich2342's Avatar
rich2342
The battery cable was disconnected for the job and done correctly.
An osiris tune will follow once i add the rest of my mods.
I was just curious at this point b/c it shouldn't run out of steam at those early rpms when it was pulling nicely in the lower.
Old Mar 10, 2010 | 06:45 AM
Unique_Z33's Avatar
Unique_Z33
Ok, but if it reset your ECU or not is another story. It takes time. The 30 min it takes to install a spacer won't do it. But still it shouldn't run out of steam at 5k. Good luck.
Old Mar 10, 2010 | 06:51 AM
Unique_Z33's Avatar
Unique_Z33
Also, what exhaust do you have? I was reading on this forum that dyno's prove tanabe loses top end power. Also test pipes/hfc's will greatly improve top end.
Old Mar 10, 2010 | 08:15 AM
rich2342's Avatar
rich2342
I've got the Tanabe Medallion touring.
I researched before purchasing and found no dyno's of this exhaust on a DE, or that it mentioned a loss of top end.
Its pointless now, if after Y-pipe/Hfc and Tune, Im sure the dynamic will change for the better.
Old Mar 10, 2010 | 09:30 AM
hellsoldiers08's Avatar
hellsoldiers08
someone mailing B.S.. Because i have the exhaust and people at uprev(austin) them self said they never seen one of the Z's make power across the whole rpm(as in gain from the bottem up it never touched) just from basically test pipe & tune(had stock y pip, stupid me). o look for me some time soon as im getting a retune next week with the injen LTI and MotorDyne XYZ Y-Pipe.
Last edited by hellsoldiers08; Mar 10, 2010 at 09:58 AM. Reason: grammer problems :werd:
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
