Rare noise after header install
Old Mar 24, 2010 | 05:48 PM
sam2944's Avatar
sam2944
Default Rare noise after header install
Hello guys. I installed a header in my 04 Touring Z. After this a strange noise comes from the exhaust system and looks like coming from the middle of the car where the catalistics were.
Anyone experienced this annoying noise? I also put the test pipes and 2" tubing all the way back.
Old Mar 24, 2010 | 06:16 PM
The problem is the 2 inch exhaust. Where did you ever get the idea that 2 inches is appropriate.
Old Mar 24, 2010 | 06:59 PM
bottlefedZ's Avatar
bottlefedZ
You got the rasp!
Old Mar 24, 2010 | 07:14 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
eww i would hate to hear it
Old Mar 24, 2010 | 07:24 PM
08NismoZ's Avatar
08NismoZ
Yeah I would agree 2" exhaust is small.
Old Mar 24, 2010 | 07:29 PM
0jiggy0's Avatar
0jiggy0
Old Mar 24, 2010 | 09:57 PM
screener's Avatar
screener
Put the other header on.
Like others said you have rasp, it is mainly the test pipes causing the worst of it. My car sounds like sh*t, but f*#k it.
Old Mar 25, 2010 | 04:49 PM
sam2944's Avatar
sam2944
Sorry...... was 2.5"
Old Mar 25, 2010 | 04:50 PM
sam2944's Avatar
sam2944
Removing the test pipes can solve the rasp?
Old Mar 26, 2010 | 02:43 PM
Gingervitis526's Avatar
Gingervitis526
Check your gaskets to make sure one of them didnt explode.
Old Mar 26, 2010 | 03:09 PM
screener's Avatar
screener
Most of it depending on your exhaust setup. All of it if you are using stock exhaust.
Old Mar 28, 2010 | 06:47 PM
sam2944's Avatar
sam2944
Gaskets are ok, Alphawerks headers and test pipe and resonator removed, 2.5" pipe
Old Mar 29, 2010 | 03:44 PM
sam2944's Avatar
sam2944
More support please
Old Mar 29, 2010 | 03:47 PM
350ztttt's Avatar
350ztttt
Just put my headers on today! can you describe the annoying noise in a little more detail? Mine is making all sorts of raspy hissing and popping noises (which I love), and I also have a custom ypipe, hfc's, and exhaust.
It might be the normal sounds if your gaskets are fine.
I think I messed something up though, because my car smells like burnt Indian food when I gun it...
Old Mar 30, 2010 | 05:58 AM
sam2944's Avatar
sam2944
Is the common known rasp!
Old Mar 30, 2010 | 06:00 PM
sam2944's Avatar
sam2944
Should I remove the header and left only the test pipes?
Old Mar 30, 2010 | 06:20 PM
0jiggy0's Avatar
0jiggy0
Why dont you give us a description, sound clip, or movie of the noise. The Z makes tons of noises stock, and even more modded.
I have no idea wtf your talking about.
Old Mar 30, 2010 | 11:10 PM
kramykram's Avatar
kramykram
Old Mar 30, 2010 | 11:11 PM
kramykram's Avatar
kramykram
The problem is the 2 inch. Where did you ever get the idea that 2 inches is appropriate.
From all the women who have lied to him. Said size does not matter!!!
Old Mar 31, 2010 | 09:13 PM
screener's Avatar
screener
Sam
The noises you are hearing is refered to as rasp. We all have it in some form from switching OEM exhaust components for aftermarket. Once you remove the factory cats it will be there. Sounds like a thousand mice are running wild in your exhaust when you apply moderate throttle.
Live with it or go back to OEM cats, better yet full OEM exhaust system.
Sorry also forgot to address the headers, those should have never been installed, waste on our motors.
