Pop Charger vs heat, tests with OT-2
Old Jun 18, 2010 | 08:52 PM
T_K's Avatar
T_K
Originally Posted by Dave B
Underhood heat isn't going to clear out that fast seeing that 20mph isn't a whole lot of air movement. I've got a data logger myself and have tested this religiously. It takes a solid 3 to 4 seconds to see a significant drop in IAT values when going WOT from a stop. On a hot day, it could take even longer.
The 0 to 40mph portion of a 1/4 mile race is the most crucial. If the engine is ingesting hot air in 1st, it's going to be slower and won't launch as hard. Now if you're racing on a sub 60 degree day, then having an aftermarket intake probably won't make you any slower at all. But if you're racing in hot temps (80+), you'll be slower.
High intake temps result in reduced timing and a richened fuel mixture to cool the combustion chamber and stop knock. Both adjustments kill power. So, not only does the hot air have less available power, the ECU is compensating to keep itself from pre-detonating itself to death.
As Motordyne as shown, aftermarket intakes do nothing for these cars and in some cases they'll slow you down. The OEM intake setup on the Z is close to ideal. I guess for some, the added noise of an intake is worth having a potentially slower car.
That's assuming zero throttle modulation, and no launch rpm compensation for grip conditions. I don't doubt the engine is thermally handicapped to some extent, but I doubt it's overall performance(at the track) effect is as significant as the fact alone makes it seem.
Old Jun 19, 2010 | 04:05 AM
rich2342's Avatar
rich2342
Regardless of Air intake temp what about increased air volume? Isn't the engine still breathing better?
Old Jun 19, 2010 | 08:32 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by Jeff92se
I don't like the idea of having to start out from lights etc.. with the ecu retarding the timing because it's seeing a high IAT reading.
I'd give up whatever preceived high end that people think the stock airbox loses than sacrifice my lowend. The 06 airbox is what I'm running. But I've run the stillen. These are the only two intakes worth running at all IMHO
^ Me and this cat here debated this extensively a while back, lol. We agreed to disagree.
Im with you, Terra. We may lose a few (no way 10-15) in the first few seconds, but make up for it in the top end. There is just simply no way heat soak will counter a much larger velocity stack and more filter area with increased flow characteristics over a dry, flat filter pulling air from one location.
Old Jun 19, 2010 | 10:52 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Honestly, even if the effects of the heatsoak robs us of valuable power during the initial launching of the car, the power difference is probably minor enough to be negligible (read: other factors contribute much more to your overall performance, such as one's skills/abilities but mainly consistency).
I've been using a Popcharger for years now in the TX heat.
Either way, when you're doing any sort of racing you're not standing still for long. I've given much thought to this issue too (as old as the my350z history) and my solution was not to enclose the filter in a casing (similar to stock airbox) but to allow for faster cooling via an air duct.
Old Jun 19, 2010 | 11:00 AM
GeauxLadyZ's Avatar
GeauxLadyZ
^ You mean like Varis duct? Or just the stock duct?
Ive got the NIsmo V2 duct installed, so i hope it is doing job in routing air more quickly and efficiently to the filter area. Not near better than Varis style duct, though.
Old Jun 19, 2010 | 11:36 AM
3hree5ive0ero
Retired Admin
I have the Titek, but yes, same general style.
Old Jun 19, 2010 | 12:48 PM
SniperHunter's Avatar
SniperHunter
Since this is a thread about heat soak, which material is more resistant to it: aluminum or plastic? I'm thinking of buying a Z1 Performance Z-Tube and imagine plastic is better.
Old Jun 19, 2010 | 12:57 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Plastic would be better, yes. But also stock is not smooth flowing due to those accordian bend grooves it has in it. I would imagine that would disrupt air flow greatly.
I have the Berk Tech Z-tube, and would like to think the air is moving so quickly through that short amount of tube that the difference between the heat of the plastic to aluminum wouldnt make all that much of a difference.
Old Jun 19, 2010 | 01:51 PM
Zazz93's Avatar
Zazz93
Try the Samco tube... I would imagine the heat properties are better than aluminum and cleaner than the accordian.
From Z1
Old Jun 19, 2010 | 02:08 PM
03threefiftyz's Avatar
03threefiftyz
I use the samco on my car.....no issues.
Old Jun 19, 2010 | 02:12 PM
SniperHunter
Thanks, gang. Yeah, the accordion is the reason why I'd like to get a Z-tube.
Old Jun 19, 2010 | 05:23 PM
o2sys's Avatar
o2sys
Why did NISSAN put the accordion there anyways???
Old Jun 21, 2010 | 08:00 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Who knows. Prob just for ease of flexiblity of the pipe when taking out, to prevent creating a stress point on plastic at the bend, i dunno.
I think its so you can push the front section back alittle (compress accordian) to help easily uninstall without breaking. Either way, its a performance no-no.
Old Jun 21, 2010 | 08:49 AM
Jeff92se's Avatar
Jeff92se
I think that 5-10-15 hp figure comes from Hydrazine's extensive dyno testing on the matter of heatsoak.
But if you think the cone is better, run the Stillen. It's probably the best of both worlds. The JWT isn't IMHO
Old Jun 21, 2010 | 08:58 AM
misterniceguy's Avatar
misterniceguy
Wrap whatever tube you have with some heat barrier foil!
Old Jun 21, 2010 | 09:02 AM
03threefiftyz
^You do realize it takes less than .1 of a second for the air to go from the top of the filter to the combustion chamber when at speed......
Old Jun 21, 2010 | 09:07 AM
misterniceguy
I guess that makes .1 seconds worth of cooler air when at speed...
Old Jun 21, 2010 | 09:13 AM
  #38
03threefiftyz
1-2 degree max difference.....and that is likely pushing it. The plenum will still be scolding hot.....so of that .1 you would only be cooling it may be .03 when it's in the actual tube.
Old Jun 21, 2010 | 09:33 AM
  #39
misterniceguy
Sweet! .03 it is then.
Old Jun 21, 2010 | 11:32 AM
  #40
terrasmak's Avatar
the heat soak issue has nothing to with the popcharger. Heat soak has to do with the heating up of the engine bay. No intake can protect you from having your engine heat up.
