Injen CIA=missing at Idle
Old Nov 8, 2003 | 10:42 PM
Scanman's Avatar
Scanman
Default Injen CIA=missing at Idle
installed Injen CIA about 2 monthes ago and imediatly noticed an erratic idle (yes i diconected the battery). This is simply not worth the minamal HP gains so I decided to remove it and take my losses.
Before doing this I thought I'd try the shorty set-up and see what would happen. Well, it idles perfectly now and sounds way better because you can here the intake now.
On top of this my seat of the pants impression is that it actually makes more power. Of course its 32 degrees out side and the tires are cold, fun trying to get traction with VDC off.
CS Track
Borla dual
Injen
Grounding kit
Old Nov 9, 2003 | 08:59 AM
AP_G35C's Avatar
AP_G35C
Can you describe your problem a little more fully. I think my G coupe is doing the same thing. Did the car ever die??
Old Nov 9, 2003 | 10:13 AM
reiver's Avatar
reiver
shorty set up?
Old Nov 9, 2003 | 10:43 AM
ares's Avatar
ares
Veteran
guessing he means the short ram intake configuration, similair to the stock layout, eliminates the concern of hydrolock from having the inlet low to the ground, but still has a more efficient filter and tube design.
Old Nov 9, 2003 | 12:23 PM
LeighJr's Avatar
LeighJr
Mine misses also its really annoying cuz it makes me think something is wrong. let me know if you figure it out.
Old Nov 10, 2003 | 04:15 AM
FLY BY Z's Avatar
FLY BY Z
In the CIA isn't it reffered to as missing in action as opposed to missing at idle?
Old Nov 10, 2003 | 02:35 PM
eskimo's Avatar
eskimo
Good call.
Old Nov 10, 2003 | 04:24 PM
cheeves's Avatar
cheeves
Thought this was a thread about a new Chuck Norris movie
Old Nov 10, 2003 | 05:36 PM
mytalon's Avatar
mytalon
What is it exactly this missing? Is that why my idle is erratic?
Old Nov 10, 2003 | 05:40 PM
jesseenglish's Avatar
jesseenglish
I would assume that the O-ring on the black plastic piece that contains your MAF is not seated correctly. A CAI should not cause your engine to misfire.
Old Nov 10, 2003 | 08:42 PM
Scanman's Avatar
Scanman
Ooops, CIA , my bad, what a dork.
Anyway, the missing is like this. It idles smooth, tach needle remains steady for about 10 to 15 seconds and then will suddenly drop a couple hundred RPM and the engine will sputter for a couple of seconds and then come out of it, and then do it all over again.
Never did this before the Injen, and now that I have the short ram set up (Injen MAF still retained) it idles smooth as glass.
Old Nov 10, 2003 | 09:10 PM
mytalon's Avatar
mytalon
I have this same problem. Is there a fix with out changeing to short ram.
Old Nov 10, 2003 | 09:25 PM
ESP350Z's Avatar
ESP350Z
does the AEM intake cause the same problem???
Old Nov 19, 2003 | 11:16 PM
jimster716's Avatar
jimster716
I have, er, had the same problem with the Injen CAI. I don't know how or why but the problem disappeared after switching my motor oil. I just noticed it today while standing at the rear of the car chatting with work buddies while the car was warming up. Before it was quite noticeable at the exhaust tips...normal idle/rumble then cut out briefly with a gurgle then resume normal idle, repeat. Tonight, the idle was smooth and I mentioned it to my buddies about the problem i noticed before with the Injen during 4k miles (had regular dealership oil when installed, switched to Mobil1 with same problem) of driving and how it's gone and the only thing i changed was my motor oil and filter last saturday.
I switched to Motul 300V Power 5W40 Synthetic with a Mobil1 oil filter.
Going to re-evaluate tomorrow after my 40 min commute to confirm.
I have no idea how or why this would make a difference besides Motul themselves touting low volatility and low evaporation. But if it works for me, I'm going to stick with it.
Old Nov 20, 2003 | 08:32 AM
OvaYahead's Avatar
OvaYahead
I have a g35c. I took the injen CAI off for the same reason. when I came to a stop light the car would idle really rough.
did you have the piece made for for your CAI to make it a short stack?
I'm waiting for a 9 inch straight tube that I had custome made. It goes from 3 and half inches to 3 inch so then I can just use the injen CAI as a short stack during the rain season.
Old Nov 20, 2003 | 10:21 AM
MGV156's Avatar
MGV156
I have this same problem and caused my Service Engine Soon lamp to come on. Because of this problem, I don't autostart my car after the engine is fully warmed up. I'm going to email Injen and let them know that I'm not the only one having this problem.
Old Nov 20, 2003 | 10:28 AM
jtree007's Avatar
jtree007
Charter Member #53
Check all your hoses to make sure there is a good seal on all of them... Mine started to start idleing rough abd it was just a loose hose
Old Nov 20, 2003 | 10:51 AM
joebva's Avatar
joebva
Mine is doing the same thing. I put on the full CAI and the SES.
I notice it at the tach and hear it standing outside next to the exhaust.
I will check the connections this weekend. I have not re-checked anything since installing 3 months ago.
Old Nov 20, 2003 | 11:13 AM
FairladyZ's Avatar
FairladyZ
Sounds like bad installs? No problems here.
Old Nov 20, 2003 | 11:32 AM
OvaYahead's Avatar
OvaYahead
everything was installed correctly on mine. The only thing I can think of is that it was for an AT g35c. I had it before they came out with the one for the 6mt.
