Engine Misfire after bolt-ons. Help!
Old Jul 17, 2010 | 05:57 AM
CodyD's Avatar
CodyD
Default Engine Misfire after bolt-ons. Help!
Installed bolt-ons on my car last (5/16 plenum spacer, JWT Popcharger on a Z1 intake tube, Z1 test pipes, Invidia Gemini catback exhaust, and a Zex wet kit).
When I started the car it was skipping pretty roughly and giving the blinking service engine soon light.
I tested all 6 coils and it made no difference,they all seemed well. Tripled checked to make sure all lines were connected.
What do you guys think the problem could be?
Old Jul 17, 2010 | 05:59 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
throttle body connection and maf connection.
Old Jul 17, 2010 | 06:02 AM
CodyD's Avatar
CodyD
I checked the MAF and it was fine too, and I'm pretty sure a friend checked the throttle body connection.
Old Jul 17, 2010 | 06:09 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
somethings unplugged just check everything you took apart.
Old Jul 17, 2010 | 06:10 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
dissconnect no2 and see if it runs any better.
Old Jul 17, 2010 | 06:15 AM
CodyD's Avatar
CodyD
By no2 do you mean the nitrous?
I unhooked it and it didn't make a difference either.
Old Jul 17, 2010 | 06:19 AM
Pig Pen's Avatar
Pig Pen
If all that went on at the same time, a simple tune from a Nissan Dealership should help too. Had a similiar issue when I changed to the Kinetix Plenum and PopCharger. It drove fine, but idle was REALLY rough and sputtered. A re-tune to re-map the MAF took all of about 15min and he drives like a champ now.
Old Jul 17, 2010 | 06:22 AM
CodyD's Avatar
CodyD
I thought about this also, but my car idles AND drives rough...
Old Jul 17, 2010 | 06:23 AM
DavesZ#3's Avatar
DavesZ#3
Air leak somewhere. MAF sensor backwards?
Old Jul 17, 2010 | 09:38 AM
SniperHunter's Avatar
SniperHunter
Reinstall the plenum. You sound like you have an air leak somewhere.
Old Jul 18, 2010 | 07:51 AM
CodyD's Avatar
CodyD
I got the car to stop misfiring and was going to close the hood and when I did, the hood hit the popcharger and pushed it down. when it did, the red MAF wire split open and it touched a bolt or something and grounded out. Now the car won't start and the TCS and Slip light are on. The car will turn over but isn't firing. I checked all the fuses in both panels and a friend tried to scan it with a scanner from 2005, but the car is a 2006 model, and it wouldn't read anything at all. My guess is that the computer is toast, although I don't know how that one wire grounding out could cause that to happen. If I'm wrong, please let me know. I need all the help I can get!
Old Jul 23, 2010 | 11:48 AM
str8dum1's Avatar
str8dum1
flatbed to the dealer sounds like the best option considering the problems due to basic bolt-ons.
good luck!
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
