My motordyne spacer
Old Aug 19, 2010 | 01:26 PM
JDMStanced's Avatar
JDMStanced
Originally Posted by TheFarmer
They break.
i'm not saying super tight. just about around 140 in lbs..
Old Aug 19, 2010 | 07:50 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by 350zRiot
Finally i received my MD 5/16" plenum spacer today morning. What i noticed from this spacer is that the gaskets (i think they are gaskets) are attached to the spacer in which i cannot take them off. ...
Am i just seeing these changes on the parts because they are upgraded?
Yes, the bonded gasket was a new innovation back in 2006. I made a post about it when it was first released.
The pre-bonded gasket makes installation a lot easier and it also greatly improves the sealing performance.
If there is a stumbling idle, there can be a number of various causes. You would need to go through a trouble shooting process to see what the cause of the problem is.
Tony
Old Aug 19, 2010 | 08:30 PM
JDMStanced's Avatar
JDMStanced
Tony
Motordyne guy! hi. i have some questions for you. After i tighten all the bolts, i drove the car for a few miles and let it cool down in my garage. I go over all the bolts again and they are loose...what's going on? This happened twice today. I didn't use a torque wrench but i did tighten them up 100inch lbs or more. I don't think it could be less than 95 inch lbs.
One more thing, do i need to apply oil on the gaskets that are attached to the plenum spacer?
OH BTW, after i tightened up the bolts that are attached to the MREV, they droppage of the RPM was gone.
Old Aug 20, 2010 | 12:10 PM
Hydrazine's Avatar
Hydrazine
The gaskets are made thick and compliant to help insure a good seal. They will compress slightly over the first few thermal cycles.
And oil is only applied to the Aramid lower manifold gasket. Not the spacer gasket.
Old Aug 21, 2010 | 11:12 PM
JDMStanced's Avatar
JDMStanced
I luv the spacer! i can definitely feel the pull above 4k rpm..almost banged my head to the seat cause i wasn't expecting it lol.
Could the oil pressure have dropped a little bit after plenum spacer installation? I'm not sure but i think it dropped some.
Old Aug 22, 2010 | 04:21 AM
Hydrazine's Avatar
Hydrazine
It will have no effect on oil pressure up or down.
_koubie_
Sep 20, 2015 06:34 PM
