My motordyne spacer
Old Aug 18, 2010 | 07:44 PM
JDMStanced's Avatar
JDMStanced
Default My motordyne spacer
Finally i received my MD 5/16" plenum spacer today morning. What i noticed from this spacer is that the gaskets (i think they are gaskets) are attached to the spacer in which i cannot take them off. To me, this is different than what i saw on the MD website. Also, around the spacer, there are some lines like puzzles. (can't explain lol. attached pic) This is weird because few days ago on this forum, I saw guys saying that MD spacers do not have this puzzles looking lines. This spacer shipped right from Motordyne Engineer and all parts says they are from MD. Am i just seeing these changes on the parts because they are upgraded?
Old Aug 18, 2010 | 08:01 PM
JDMStanced's Avatar
JDMStanced
Also, the 6 white cups (spacers) are black on mine. All websites show MD spacer cups white not black..
Old Aug 18, 2010 | 08:04 PM
dmroberson's Avatar
dmroberson
You're just seeing the differences between the first "generation" and now... nothing to worry about. Mine has the white spacers, and no "puzzle" lines, but I've had it for over 3 years now.
Old Aug 18, 2010 | 08:07 PM
WhosRich's Avatar
WhosRich
I just encountered this same problem myself. Tony himself said that some spacers do have "dovetails" and that they are genuine and perfectly fine. If you bought it directly from them, you have nothing to be worried about. I'd find it more authentic because it came with the gasket attached. Some imitation spacers dont even come with it.
Old Aug 18, 2010 | 08:18 PM
G4nismo's Avatar
G4nismo
yeh, i bought 1 recently and they were exactly the same. don't worry about it.
Old Aug 18, 2010 | 08:20 PM
WhosRich's Avatar
WhosRich
If you have doubts, just call or email tony himself. He can authenticate it for you.
Old Aug 18, 2010 | 08:58 PM
Looks like a simple change with the gasket fused to the spacer.
Old Aug 18, 2010 | 09:01 PM
JDMStanced's Avatar
JDMStanced
i wouldn't worry about it then.
I ordered it from CvR motorsports but then they are suppose to get the supply on 27th (i think). This wasn't indicated on the website so i just ordered without knowing. Then Chris from CVR worked something out and MD sent it directly to me
Old Aug 18, 2010 | 09:10 PM
JDMStanced's Avatar
JDMStanced
i finished installing it now. lol. it sucks i don't have a torque wrench that goes down to 10 inch lbs. What would happen if i tighten the bolts too weak or too tight?
I feel like the 100 inch lbs bolts are tighten too weak. I fully hand tightened with 10mm socket and a extender.
Old Aug 18, 2010 | 09:14 PM
WhosRich's Avatar
WhosRich
Just go with the torque specs they give you man.
Old Aug 18, 2010 | 09:18 PM
JDMStanced's Avatar
JDMStanced
i don't have the torque wrench for it. I asked kragen but they don't carry torque wrench under 10ft lbs. And i already have 2 torque wrenches
Old Aug 18, 2010 | 09:36 PM
SoldzMyZ's Avatar
SoldzMyZ
My powerlab spacer has the puzzle lines. I've had it for about 8 months give or take and its all good.
Old Aug 18, 2010 | 10:12 PM
JPsZ's Avatar
JPsZ
I installed my MD spacer a few weeks ago. I didn't have a torque wrench as well, I just used a regular 3/8in. ratchet and was very careful. Install was a breeze, no leaks. If you feel the need, use a screwdriver type 1/4in. or 3/8 drive, like this below. It'll will help so you don't overtighten them. Isn't that shown on your install manual?
Motordyne install manual
http://www.motordyneengineering.com/manual.pdf
Old Aug 18, 2010 | 11:15 PM
JDMStanced's Avatar
JDMStanced
There's air leak either from the spacer or my homemade oil catch can
During idle, the RPM goes down slowly and when it reaches 900rpm, the car shakes and rpm goes up little bit and goes down again, repeat, and repeat. I checked all the hoses and bolts and they were there fine. During installation, I took out my catch can and lost the rubber ring that seals between the can and its body..lol. So i applied enuff silicone around the edge so that it could work like sealant instead of the rubber ring. Could this lead to air leak?
Old Aug 19, 2010 | 09:39 AM
JPsZ's Avatar
JPsZ
you can buy a basic o-ring kit at your local parts store. it comes with multiple sizes and should be cheap. Otherwise I'd say it's a vacuum leak from your install. Remove the spacer, inspect the sealing surfaces, and apply oil to the gasket to help seal it.
Old Aug 19, 2010 | 09:59 AM
JDMStanced's Avatar
JDMStanced
oh was i suppose to apply oil to the gasket? i used both the old gasket and the md spacer
Old Aug 19, 2010 | 01:09 PM
JDMStanced's Avatar
JDMStanced
this morning, i checked all the bolts but they all were loose including the plate that attaches to the MREV. Maybe that caused that air leak inside..
i tightend the MREV bolts and the car runs little bit better but still not perfect.
What happens if i tighten those bolts too tight?
Old Aug 19, 2010 | 01:20 PM
WhosRich's Avatar
WhosRich
You are supposed to oil the gasket. When the engine heats up, the oil causes the gasket to expand.
Old Aug 19, 2010 | 01:22 PM
TheFarmer's Avatar
TheFarmer
They break.
Old Aug 19, 2010 | 01:25 PM
JDMStanced's Avatar
JDMStanced
my plenum spacer is attached with the gasket around. i watched vids on installing this but they didnt apply oils..
