Popping in exhaust.
Old Oct 7, 2010 | 10:08 AM
enthusiazt's Avatar
enthusiazt
ok that makes a lot of sense ( about removing the heat shields). I will try that hopefully this weekend and see what results i get and what other sounds it leaves me with. Thanks a lot guys!
Old Oct 9, 2010 | 09:15 PM
Shawz1102's Avatar
Shawz1102
I have Motordyne's ART Pipes and i have the rattling issue as well around 3k-4.5k when the outside temperature is really hot (like 110+)... Other than that, i also have the rattling issue everyday regardless of outside temperature if i slowly disengage the clutch in first gear almost to the point where the car is going to die out.. Other than that, no rattle...
Any fix? Does this sound like your problem?
Old Oct 10, 2010 | 06:06 AM
Z_enthusiast's Avatar
Z_enthusiast
Read bro... read. sometimes its your cat heatshields rattling.
Old Oct 10, 2010 | 12:26 PM
singh's Avatar
singh
_______________
i have a lot of popping in my exhaust too.. but it only happens after I push the clutch in between shifts or when I am decelerating with the car in gear (engine braking).
i kinda like it lol
Old Oct 10, 2010 | 04:26 PM
Kuhan's Avatar
Kuhan
^My Nismo exhaust was making popping sound after installing Berk hfcs when decelerating.
But after installing Stillen G3 dual intakes, the popping sound was gone completely.
My guess is the restricted stock intake could cause the popping sound?
Old Oct 11, 2010 | 12:36 PM
enthusiazt's Avatar
enthusiazt
ok so i literally just pulled the heat shields off, this fixed the rattling by maybe 5%. kinda pissed cause i thought that would be the fix. Popping still there but im thinking this may be an exhaust leak. When i look under the car, coming from the driver side test pipe, where the test pipe connects to the catback is some exhaust gases seaping, i feel the heat when i put my hand next to it. would tightening this fix the exhaust leak ?
Old Oct 11, 2010 | 02:42 PM
Z_enthusiast
Possibly... but if you cant get it tighter without straining stop... you dont wanna break the stud or anything. try to tighten it a lil if its tight youll need another gasket.
Old Oct 11, 2010 | 03:44 PM
Jairen's Avatar
Jairen
My AFR was a little off after I got test pipes also. The tune fixed it.
Old Oct 11, 2010 | 06:48 PM
enthusiazt's Avatar
enthusiazt
btw, i have a nismo cai.
Old Oct 11, 2010 | 08:18 PM
Shawz1102's Avatar
Shawz1102
Heatshield as in the bracket that holds the cats? I removed that due to installing ART pipes... So no heatshield, nothing supporting the ART pipes... And it's still rattling.
Old Oct 12, 2010 | 09:10 AM
enthusiazt's Avatar
enthusiazt
nah there is heat shields above each cat, not the brackets. If you can get under your car and look above the test pipes, you will notice a piece of flimsy metal held by three 10mm bolts.
Old Oct 12, 2010 | 06:51 PM
Shawz1102's Avatar
Shawz1102
Oh ok i think i know what you're talking about... But i dont understand how my pipes can be hitting that thing... It's literally an inch or so away from it...
So you're saying that in order to get rid of the rattling, i'd have to take off the heatshield? Wouldn't the pipe just hit the frame of the car or whatever is under the heatshield then?
Old Oct 12, 2010 | 07:24 PM
Z_enthusiast
the humming/soundwaves make it vibrate
Old Oct 13, 2010 | 09:12 AM
enthusiazt's Avatar
enthusiazt
i didnt notice too much of a difference by taking them off, but it could help you maybe since others noticed a dramatic change.
Old Oct 13, 2010 | 09:16 AM
Shawz1102's Avatar
Shawz1102
I'll just keep it on then, i mean they're on there for a reason... I'll just endure through the annoying vibrations when the weather is extremely hot...
Wow you two almost have same identical names, got me confused for a minute hah
Btw op: so you got all your popping fixed now?
Old Oct 16, 2010 | 01:10 PM
enthusiazt's Avatar
enthusiazt
nah its still there. im getting used to it now lol. The rattling is what gets me mad.
Old Oct 16, 2010 | 03:21 PM
Z_enthusiast
Ok... i just did TWO test pipe installs. one is still on jack stands waiting for the core support to come in so i havnt started it but i just did one today and he has Injen dual cold air and Greddy evo 2 with berk test pipes. after hearing his car i think i know what your popping is. When he is around 2k-3.5k rpm it has a like a hollow tin can popping/rattling noise correct?
Old Oct 16, 2010 | 03:30 PM
  #38
Neu Era's Avatar
Neu Era
Originally Posted by tylerxfire
thats absolutely false..if someone has a rattle from installing test pipes then there is install error..i went thru 2 sets of high flows and 2 sets of test pipes and never had a rattle..along with many other people i know who run them...
I have had rattles everytime I've done installs..and yes they were done correctly..
Old Oct 16, 2010 | 03:31 PM
  #39
Neu Era's Avatar
Neu Era
But then again, It could just be vibration?!?!
Old Oct 16, 2010 | 04:36 PM
  #40
Z_enthusiast
i think hes talking abt the rasp that comes with test pipes. it has a popping sound at a certain rpm. i heard it for the first time today, after a greddy evo2/berk pipes
