xo2 with magnaflow x pipe and resonated test pipes
Old Oct 18, 2010 | 01:19 PM
350zhr's Avatar
350zhr
Default xo2 with magnaflow x pipe and resonated test pipes
i couldnt ever find any real good videos of this exhaust with the resonated magnaflow x pipe so i decided to make one. i also have cnt racing resonated x pipes. I did some normal driving for most of the video and did a full throttle pull at the end.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/n3WsfoYxCAs?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/n3WsfoYxCAs?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
It sounds much much better now than it did before the x pipe. the x pipe and test pipes were installed at the same time.
Old Oct 18, 2010 | 02:08 PM
jv350z's Avatar
jv350z
Great video. I'm looking to get this same combo. I have the CNT/ERZ HFCs.
Old Oct 18, 2010 | 04:18 PM
350zhr's Avatar
350zhr
thank you, it does sound even better in person.
Old Oct 18, 2010 | 05:48 PM
User 42426's Avatar
User 42426
used to have hks duals with cnt test pipes. Loved the sound, so much deeper in person.
Old Oct 19, 2010 | 08:21 AM
sex-Z's Avatar
sex-Z
did you get any CEL's? and can you pass smog with the test pipes/HFC? I have the same exhaust on my 07 ppw, im looking for ways to love it even more.
Old Oct 19, 2010 | 07:52 PM
350zhr's Avatar
350zhr
i do have the service engine soon light on. i couldnt answer your smog question we dont have that in NY.
Old Oct 19, 2010 | 09:47 PM
Jairen's Avatar
Jairen
Here's mine with test pipes and the magnaflow resonated x-pipe on the dyno. Where did you mount the x-pipe?
http://www.youtube.com/watch?v=icbzSlrNdBc
Old Oct 20, 2010 | 03:20 PM
350zhr's Avatar
350zhr
i replaced the h pipe and resonators with the resonated x pipe. i believe that just how you did it. mine and yours do not sound as much alike as i thought they might. maybe it has something to do with my car being a hr.
Old Oct 23, 2010 | 09:19 AM
jaaf's Avatar
jaaf
how much did the install cost u guys? i just got estimated $350
Old Oct 23, 2010 | 09:22 AM
VERTZ's Avatar
VERTZ
sounds good
Old Oct 23, 2010 | 04:59 PM
350zhr's Avatar
350zhr
Originally Posted by jaaf
how much did the install cost u guys? i just got estimated $350 for the xpipe and to replace the flexpipes(mine are messed up from being too low)...
i did the test pipes and took the exhaust off myself, one of my buddies is a very good welder. so i had him cut the exhaust and weld in the x pipe. so it was free.
Old Oct 24, 2010 | 12:30 PM
dwrecckk's Avatar
dwrecckk
60 bucks to weld in the x pipe, i was charged 80 total to heat up the rear section and straighten it out as well.
Old Oct 24, 2010 | 12:36 PM
Entaille's Avatar
Entaille
that sounds pretty good.
Old Oct 24, 2010 | 04:03 PM
Shawz1102's Avatar
Shawz1102
xo2 + x pipe is basically the Ark pipe. Their exhaust is exactly the same as HKS and they claim it's not a knockoff by using the x pipe instead.
Old Oct 24, 2010 | 04:30 PM
350zhr's Avatar
350zhr
i wouldnt exactly say its the same because the xpipe is resonated and arks is not but runs into two single resonators which come apart inside.
Old Oct 25, 2010 | 02:33 PM
dwrecckk's Avatar
dwrecckk
"X02" is 2.5" diameter, HKS is 2.25", thus not exactly the same
X02 > HKS except for the resonators and the tips, and obviously fitment.
Old Oct 25, 2010 | 04:42 PM
Jairen's Avatar
Jairen
The difference is, we are using a resonated x-pipe where ARK uses an unresonated x-pipe. the resonated x-pipe greatly reduces in cabin drone and rasp. ARK still hasn't posted a sound clip with HFC's or test pipes. Either way, it still looks like a quality system by looking at the pictures.
Old Oct 25, 2010 | 04:53 PM
Shawz1102's Avatar
Shawz1102
Thanks for the info.
But do you guys know if adding the magnaflow resonated x pipe would cause power/torque changes (+/-)?
I'd buy the XO2 exhaust but the cheap tips and fitment issues are keeping me from taking the plunge...
BTW Op, do you have a video clip of the xo2 pre adding the magnaflow x pipe?
Old Oct 25, 2010 | 05:19 PM
350zhr's Avatar
350zhr
just an incabin video, no test pipes either. probably wont help much... but if you view my other videos there is a video titled ensign pond road, thats it.
and as for fitment my driver side tip is a little low. i painted my tips and the cans semi gloss black with some high temp paint. i like it better than bunrt tips anyway.
Old Feb 17, 2011 | 10:54 AM
bmccann101's Avatar
bmccann101
Default bump.
old thread, but in for this set up...
thanks for the clips.!
XO2 already installed, magnaflow 2.5 in resd x pipe on my garage floor, and Intense power resd test pipes n non foulers going on at time of x pipe installation. (Also doing new master/slave n ss lines, JWT fly n clutch combo as well as POP charger and a TWM short shifter w solid trans mount bushing.. should be a totally diff car after its ready to be picked up. )
Sounds good to me.
