HR intake options
Old Jan 16, 2011 | 07:58 PM
redzblackh's Avatar
redzblackh
Default HR intake options
I already have stillen gen 3 intakes, are there any other upgrades I can do intake wise with the HR motor?
Old Jan 16, 2011 | 08:34 PM
KingBaby's Avatar
KingBaby
Hardest Setting
what esle do you want to do?
Old Jan 16, 2011 | 08:40 PM
Arvin89's Avatar
Arvin89
Plenum spacer? and possibly the mrev 2 plenum upgrade(not sure if you can on the hr).
Old Jan 16, 2011 | 11:16 PM
Gen #4 silly.
Old Jan 17, 2011 | 04:32 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
even your existing intake is hardly worth the price of admission, so no, there are no other changes or upgrades worth doing
Old Jan 17, 2011 | 04:33 AM
Z1 Performance
Former Sponsor
HR's have nothing in common intake wise or component wise with DE's so these parts are not compatible
Old Jan 17, 2011 | 06:18 AM
redzblackh's Avatar
redzblackh
yeah i know i cant use the same intake products (manifold, spacer) as the previous 350z's thats why i was asking if anybody knows where to get something for HR. and, 20whp id say is worth $499
Old Jan 17, 2011 | 06:20 AM
Frosty87's Avatar
Frosty87
did you dyno before and after to prove 20whp ...just saying
Old Jan 17, 2011 | 06:42 AM
archangel72's Avatar
archangel72
If you have the best after market, I would think bout better flow after the intake. Has anyone with an hr ever extrude honed their manifold? Is it worth it?
Old Jan 17, 2011 | 07:15 AM
Rubidium's Avatar
Rubidium
Water/meth injection...........maybe
Old Jan 17, 2011 | 07:34 AM
sportbiketed's Avatar
sportbiketed
That would be pointless since he is not boosted.
Old Jan 17, 2011 | 08:51 AM
Z1 Performance
Former Sponsor
if you legitimately gained 20 whp under the curve it would be worth a multiple of $499 - but the fact of the matter you wouldn't realistically be able to achieve that type of gain with 5 x the investment. A peak gain of 20whp is different - and I'd be curious how often it is duplicated. Never mind the fact that intake 'gains' are very difficult to actually quantify, far more difficult than an exhaust mod. I'm a Stillen dealer, so I am genuinely interested
Old Jan 17, 2011 | 10:48 AM
ace32x's Avatar
ace32x
if ur not boosting it in the future, exhaust testpipe's intake tune and call it a day best ur gonna get with out doing some motor work
Old Jan 17, 2011 | 10:49 AM
ace32x's Avatar
ace32x
and as for intakes theyre all fairly similiar i dont think switching would get u any gains and if they were they wouldnt be worth the $.
Old Jan 17, 2011 | 02:23 PM
0jiggy0's Avatar
0jiggy0
What the hell is going on in this thread? Plenum spacer and Water/meth on an NA HR?
Old Jan 17, 2011 | 02:56 PM
doshoru's Avatar
doshoru
The idea behind a CAI is to pull in colder air, as colder air supplies more oxygen than hot air. Physics-wise, it's b/c hot atoms/molecules bounce around a lot, and occupy more "space", thus meaning less of any atom/molecule can occupy a given volume of space. Your engine heats the ambient air under the hood, so it contains less oxygen. Less oxygen = less hp.
So a CAI is a long tube whose filter sits outside of/at the edge of the engine bay. The negative aspect of this setup is that throttle response typically suffers, as the air has to travel a farther distance when you suddenly stab the gas.
The problem is....well, the problem is that there are tons of problems determining the real-world effectiveness of a CAI. Chief of which is....in almost any situation, their is going to be a massive amount of airflow passing through the bumper & through/around your radiator, flushing out most of that hot air under your engine bay. But, we don't really care about the entire engine bay, b/c with a short-ram or stock-style intake, the filters are located almost directly in front of the bumper!!! Once the car starts moving, you're going to see only a couple degree difference between the intake charge on the CAI's vs the SRI's!!!
Anyways, my belief is that the 20whp gains may be factual, but only for a split second, and only from a dead stop under really freaking hot conditions, where you're probably going to be traction-limited, anyways.
Cliff's Notes: Even if the Stillen CAI granted you X more power than any other intake, it would only be for a split second from a dead stop, and only if it were hot as ***** outside. Reason being, as soon as you start moving, ambient air is going to flush out the hot air under your hood.
Old Jan 17, 2011 | 03:37 PM
TPete19's Avatar
TPete19
He just threw a number out there. No need to start debates in every thread.
+1
You've already got one of the best (along with the Injen) intakes. If you're going to stay NA, throw on some hi-flo cats, an exhaust, and top it off with a tune. That's really all you can do without boosting.
I guess you could throw in a shot of nitrous, but I know nothing about that stuff.
Old Jan 17, 2011 | 08:09 PM
07_350z_JP's Avatar
07_350z_JP
I proved this comment false a while back when I still had my stock and Stillen Gen 1 intakes.I datalogged IAT on my car (with LM1) and even the stock and stillens that are fully enclose/shielded get a bit of heatsoak.It was within 5 degrees of stock though.After idling for 2+ minutes (temp would increase 60-80) over ambient)it would take 4 minutes going 70ish to get the temps back down to with 10-15 degrees of ambient. NOT seconds.
My point of all this is that if you replace the intake make sure its properly sheilded or get the true cold air (a la injen). Otherwise you will heatsoak very quickly and it take several at speed minutes to bring temps down.I now have the Injen Long Tubes that I will datalog soon but no longer have the stock ro stillens to obtain same day results.
Old Jan 18, 2011 | 03:51 AM
redzblackh's Avatar
redzblackh
well ive went from short tubes to the long tubes in the bumper (gen 3) and i can deffinetly feel the difference. between the two.
yeah i know intake, exhaust, test pipes/hi flows, and tune. i was just seeing if anybody knew of anything like the kinetix manifold, hi flow lower plenum, or anything like that so that i can get the max out of my tune when i do it
Old Jan 18, 2011 | 07:03 AM
nismonian's Avatar
nismonian
this + 4:08 gears and your golden.
