Removing Motordyne plenum spacer ??
Old Apr 8, 2011 | 09:53 PM
carlos305's Avatar
carlos305
Default Removing Motordyne plenum spacer ??
So i need to remove my motordyne 5/16" plenum spacer and i'm pretty sure i replaced the OEM plenum screws with the ones that came with the spacer but i cant find my OEM screws if my life depended on it. My question is can i use the screws supplied by motordyne without using the spacer? Are they the same length as OEM screws?
Old Apr 8, 2011 | 09:56 PM
omsin523's Avatar
omsin523
I doubt you can you the use the md screws because there obliviously longer. The outer plenum bolts are m6 I think that you can find at any local autoparts store but you want to make sure to get the strongest grade. But, for the 6 in them middle of the plenum your going to have to go to nissan, while there just get all.
http://www.courtesyparts.com/350z-pa...5_716_727.html
Old Apr 8, 2011 | 10:13 PM
carlos305's Avatar
carlos305
Dam!! Ok thats what i thought thanks bro!!
Old Apr 9, 2011 | 07:53 AM
ChriZTT's Avatar
ChriZTT
Just curious as to why your removing it. Any problems?
Thanks.
Old Apr 9, 2011 | 04:10 PM
carlos305's Avatar
carlos305
Thanks.
Nope, no issues with it i'm takin it off temporarily because i need to take it to the dealer for oil consumption issues and would like to avoid any BS excuses from the dealer about the car being modded.
Old Apr 9, 2011 | 04:12 PM
carlos305's Avatar
carlos305
Btw... I went to nissan today to see how much these screws would cost and got quoted $150!!!!!!!
Old Apr 9, 2011 | 08:58 PM
ChriZTT's Avatar
ChriZTT
Dam! Sorry to hear that.
BTW what year is your Z? Just wondering b/c I am aware of the 06's having oil consumption problems. Also, how did you come to realize your Z was burning excess oil?
Old Apr 10, 2011 | 06:34 AM
carlos305's Avatar
carlos305
My Z is an 06 , there are many signs its burning oil, such as excessive blue smoke both when i first turn it on in the morning and in high rpms, and when i do my oil changes every 3000 miles it only drains about 1.5 qts so the other 3.5qts are gone.
Old Apr 10, 2011 | 09:33 AM
ChriZTT's Avatar
ChriZTT
Interesting. Thanks for the response. I too drive an '06 Z but have been fortunate not to have any oil consumption issues. I hope your able to resolve the issue.
Old Apr 10, 2011 | 10:03 AM
carlos305's Avatar
carlos305
No problem.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
