3/8 vs 5/16 plenum spacer
Old Apr 18, 2011 | 05:32 PM
Awscoonce's Avatar
Awscoonce
Default 3/8 vs 5/16 plenum spacer
I know that I am probably going to get a lot of crap for this, but what is the diff between the 2 plenum spacers. I'm looking into buying one and wanted to know what fit, and what didn't. I have a 2003 touring. I know that they sometimes have the problem with the strut bar. Any help would be appreciated.
Old Apr 18, 2011 | 05:44 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Assuming DE style hood (HR hood provides more clearance, so I'm not sure).
Should fit under strut bar:
5/16 Motordyne
Should fit under strut bar if you add washers under the strut bar:
3/8 Powerlab
Will not fit under strut bar:
1/2 Motordyne
Won't fit under strut bar & may even rub hood if you don't have engine damper:
5/8 Skunk2
Old Apr 18, 2011 | 08:40 PM
http://www.motordyneengineering.com/...9efbd02174f6f7
Old Apr 18, 2011 | 09:23 PM
RedlineAZ's Avatar
RedlineAZ
I had an 06 350z and I bought the 3/8 spacer....and they gave me washers for strut bar spacers (looked very ghetto, 4 washers stacked for each bolt of the strut bar) and the hood hit my strut bar and wouldn't close right so it left a nasty gap in between my hood and fender! It looked like my car was in an accident and the body gaps were off or something. It was a worthless piece of junk! So I sold it to a g35 coupe owner who didn't have a strut bar, and he liked it. I then bought the 5/16 spacer and they gave me nice aluminum strut bar spacers with it, and hood clearance was perfect and the hood closed fine!
The 3/8 will give you more top end gains, the 5/16 more low end....but honestly I never revved up that high on a daily basis to notice a difference with a 3/8, and the hood hitting the strut bar threw me over the top. Go with the 5/16, you can't go wrong
Old Apr 19, 2011 | 10:20 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Cannot believe this debate still exists in 2011.
Old Apr 19, 2011 | 12:49 PM
SparkleCityHop
Living in 350Z
Not sure that any of the spacers alone will give you any real world gains without a tune. Even if so, it's not anything you can notice in performance. You'll probably just notice a different sound to your intake/exhaust tone.
If you've also upgraded your intake, lower plenum (mrev2), cats, and exhaust, you may improve breathing overall to see some noticeable gains with a tune.
I've had the 5/16 and the 5/8 spacers, so I've seen both ends of the spectrum.
Old Apr 19, 2011 | 12:52 PM
kacz07's Avatar
kacz07
You need cams to take advantage of spacer like that. If you want to keep a strut bar and the hood, buy a crawford strut tower brace.
Old Apr 19, 2011 | 12:53 PM
SparkleCityHop
Living in 350Z
And, yes, the mrev2 has shown dyno gains on the non-revup DE engines like your 2003 and my 2004.
This post was a pre-emptive because I expect the usual "mrev is for revup" assumptions that many believe. Motordyne has plenty of real world dyno sheets that prove the difference that their porting/polishing does for our engines too.
Again, all of this assumes a tune.
Old Apr 19, 2011 | 12:57 PM
SparkleCityHop
Living in 350Z
Or the APS tall boy strut bar
Or the Stillen strut bar.
All will clear the bigger spacers
Old Apr 19, 2011 | 01:00 PM
kacz07's Avatar
kacz07
Old Apr 19, 2011 | 01:03 PM
Jeff92se's Avatar
Jeff92se
I know that I am probably going to get a lot of crap for this, but what is the diff between the 2 plenum spacers..
1/16
Old Apr 19, 2011 | 01:19 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
There are so many redundant spacer threads.
Mods, please lock this thread and advise OP to use the search function.
Old Apr 19, 2011 | 01:21 PM
SparkleCityHop
Living in 350Z
Originally Posted by RudeG_v2.0
Some people are just afraid of the big bad monster hiding behind the search button.
Old May 3, 2011 | 07:00 PM
007mead's Avatar
007mead
When you all say "tune" what specifically are you referring to doing? Tuning the stock ECU, or something aftermarket?
What is the best way to tune once you are done with several "bolt on" upgrades?
Old May 3, 2011 | 07:26 PM
SparkleCityHop
Living in 350Z
www.uprev.com
_koubie_
Sep 20, 2015 06:34 PM
