Motordyne shockwave V2 installed......video
Old Mar 24, 2012 | 12:43 PM
  #61
Z Fo Sho's Avatar
Z Fo Sho
Originally Posted by F2CMaDMaXX
That's not a bad vid for sound, i like it a lot
Thanks man, here is a warm start up and rev
http://www.youtube.com/watch?v=VUo7J1SU334
Old Mar 24, 2012 | 02:33 PM
  #62
Z Fo Sho's Avatar
Z Fo Sho
and finally a first through second vid. Although the traction control kicks in a bit
http://www.youtube.com/watch?v=hYnVSKgN1cc
Old Mar 24, 2012 | 04:51 PM
  #63
F2CMaDMaXX's Avatar
F2CMaDMaXX
Gah, i'm now jealous, just had to go and put my unmodified rear muffler back on the car after i fitted my ART and XYZ pipes.
The rear muffler (modified straight through) was causing massive amounts of resonance drone and was generally really obnoxious without a good sound.
Now even with those clearly better pipes, it's back to annoyingly quiet, within a nats whisker of being stock volume
I yearn for the Shockwave to finish out my Motordyne car
Old Mar 26, 2012 | 09:23 AM
  #64
kyle22's Avatar
kyle22
These videos really made me want to purchase a new exhaust now!
also, this makes me confused on what the difference is between the TDX V2 and TDX2?
Old Mar 26, 2012 | 02:21 PM
  #65
sfearl1's Avatar
sfearl1
i think they're the same thing.
Old Mar 26, 2012 | 04:31 PM
  #66
kyle22's Avatar
kyle22
Well then, that will be the reason why I was confused. Thanks
Old Mar 26, 2012 | 06:05 PM
  #67
klaze1's Avatar
klaze1
hahaha, I am looking forward to buying these in the future, was supposed to get em a while back but got hit by mad bills!
Old Apr 3, 2012 | 08:12 AM
  #68
Z_YA_L8R's Avatar
Z_YA_L8R
Hey man, I really like the way that sounds! Congratulations on an awesome setup!
Old Apr 6, 2012 | 03:52 PM
  #69
kham25's Avatar
kham25
Did u lose any low end torque ? To spend all this cash on exhaust , TP then tune for couple HP .. But from your vids exhaust sounds bad ***..
Old Apr 9, 2012 | 02:02 PM
  #70
Z Fo Sho's Avatar
Z Fo Sho
I didn't lose any low end torque. It felt like i gained some low end. Now when I floor it around 2k rpms, I can break traction in first. I mostly felt it at about 4.5k rpm. I could never break traction as easily as i can now.
Has anyone come up with a solution to raising the mid-pipe of the exhaust? Its almost time for me to drop the car, and if i lower any more than 1 inch, then the midpipe will be so close to touching the ground, its too low already. Let me know if anyone had fixed this!
Old Jul 5, 2012 | 05:42 PM
  #71
2k3 3fiftyZ's Avatar
2k3 3fiftyZ
Hey Z Fo Sho, I'm lookin into getting this exhaust as well and actually live in the STL area too. Just wondering how you're passing inspection with those test pipes or if your just switching the exhaust before inspection.
Old Jul 5, 2012 | 05:58 PM
  #72
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yeah, basically you can gas seal v-band clamps without them being fully connected/straight.
You need to loosen them up and shove the joint up high, completely re-fasten if you need to, but clamp it up quick whilst you hold it or have someone else fasten it tight whilst you hold it.
I too can confirm feeling a little peppier low down, no torque feels like it was lost.
Old Jul 5, 2012 | 06:03 PM
  #73
rich2342's Avatar
rich2342
Clips?
Old Jul 5, 2012 | 06:27 PM
  #74
F2CMaDMaXX's Avatar
F2CMaDMaXX
As in, video?
Forthcoming, full review, pics and videos, just taking time to edit and i haven't captured the video yet way too busy right now
Old Jul 6, 2012 | 12:41 PM
  #75
Z Fo Sho's Avatar
Z Fo Sho
I just had my emissions done last week with the exhaust and test pipes.... It passed... no problems at all
Old Jul 6, 2012 | 05:44 PM
  #76
2k3 3fiftyZ
I see, where did you have it installed around here or did you do it yourself?
Old Jul 6, 2012 | 11:01 PM
  #77
F2CMaDMaXX's Avatar
F2CMaDMaXX
With a sniffer up the tailpipe?
Old Jul 7, 2012 | 05:03 PM
  #78
Esser's Avatar
Esser
They don't use the sniffer in Missouri, they just check for codes on the dash really
Old Jul 7, 2012 | 05:05 PM
  #79
Z Fo Sho's Avatar
Z Fo Sho
yep he's right. they didnt use a sniffer at all. I just got my inspection done at meineke right by my house and they passed it easily. Took about 20 min for the inspection.
I'll have to try raising the exhaust a little bit like explained earlier. I am about to drop the car
Old Jul 7, 2012 | 05:06 PM
  #80
2k3 3fiftyZ
So if I get test pipes and it doesn't throw a CEL or code then I don't have to worry about not passing emissions?
